Old 08-24-2011, 01:51 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Default E-Fans?
does anyone make an electric fan kit for our trucks? I know I can do it all myself but id much rather spend the money and let someone else have the headache of designing the shroud and yada yada.
Also does anyone know if this sets any sort of CEL to take the stock fan off? Figure it would be worth a few ponies and It would ne nice to be able to control fan turn on/off points
2011 Big Horn 4x4 -SnowWhite-
Old 08-24-2011, 02:15 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Your truck has an electric fan from the factory. It is what they called a "hybrid" fan system, an electric and mechanical fan. Some people have removed their mechanical fan with no issues (don't know how this would work with towing/heavy duty use, etc...) but most of those people also have a 180 tstat and tuner to adjust electric fan on temp. I believe the stock electric fan is set to run with AC on and at 222 deg F (that's what superchips tells me, even though I swear I've heard the electric fan at around 205 F).
Sean
Old 08-24-2011, 07:41 PM
SS4Luck's Avatar
Rep:310
Maybe taking the stock clutch fan off and putting on a dedicated "pusher" would help? Its def something I will experiement with once they make tuners for these 2011s
Old 08-24-2011, 09:31 PM
snrusnak's Avatar
Rep:1385
I'm not sure but isn't a "pusher" fan one that blows air from inside the engine bay, through the radiator, and out the grill? I assume the stock fan is a "puller", along with almost all electric fans. I would think a fan blowing out would not help, as the air pushed through the grill while driving would counteract this....? I think a puller would be MUCH more efficient. I think the stock electric fan is enough, I wouldn't change this unless you experience overheating once removing the clutch fan. If you do experience overheating I think the first step should be to put in a 180 tstat.
Sean
Old 08-24-2011, 10:08 PM
SS4Luck's Avatar
Rep:310
A pusher goes on the front of the radiator and pushes air through the radiator faster. Its mainly for sitting in traffic/around town driving when you may not get as much air over the radiator like you would at say, freeway speeds.
A 180* stat wouldnt do a thing unless you can tune your fans on earlier, and with a 2011 not being able to be tuned all it would do is let the stat open a littl earlier and take a little longer to reach full operating temps
Old 08-24-2011, 10:16 PM
snrusnak's Avatar
Rep:1385
ah! gotcha. Wouldn't the stock efan basically do the same thing by pulling through the radiator.....I guess I just don't see what you're accomplishing by changing the setup?
Right, I meant once a tune is available...
Sean
Old 08-24-2011, 11:32 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Theirs a kit out. Do a goggle search. I cannot remember where I saw it. Its probably worth 15 hp but you will need to buy and overdrive pulley kit. Thats the only way to take advantage of the eFan.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 08-24-2011, 11:37 PM
snrusnak's Avatar
Rep:1385
I just don't understand.....why change the stock efan setup if others are running just the stock efan with no mech fan without issues??? I would try it and see what happens and if you have overheating issues THEN address them possibly with an aftermarket kit/fan....I just don't see the need or reason for this. I would think just removing the stock mech fan would free up no more than maybe 5 hp(assuming your clutch is working properly). An underdrive pulley would be a great addition to this mod...
Sean
Old 08-25-2011, 02:27 AM
SS4Luck's Avatar
Rep:310
I didnt know about the "hybrid" setup when i made this thread. It would be interesting to see when the stock efan kicks on temp wise. Ive had a few vehicles hace heating/cooling problems before and Id rather spend $70 for an extra efan for an insurance policy than have temp problems. Ill tackle this once tuners are available so I can control the stock fan
Old 08-25-2011, 09:04 AM
snrusnak's Avatar
Rep:1385
gotcha. for reference, superchips tells me that the stock on temp for the efan is 222 deg F (I assume hemi is same as 4.7L, although I'm not sure). I swear though that I've heard the fan come on earlier, like around 205 or so....so who knows. They told me it's possible that there is another setting that they don't see and can't adjust...
Sean
Hello to all the ram fans, from mexico ALVAREZ Newbie Checkin! 13 10-12-2010 12:34 AM
Electric fans dodgethis03 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 6 06-27-2010 10:27 PM
2 fans on engine whats the reason? cajundude 2009 Dodge Ram Forum 17 02-11-2010 03:19 PM
Hello to fellow Ram/Mopar fans Andysfury Newbie Checkin! 9 01-07-2010 05:50 PM
Coolings Fans On all the time and High Oil Temps Joe Heating & Cooling 1 04-08-2009 08:54 PM
