Old 08-24-2011, 03:29 PM
diceteach diceteach is offline
Vehicle: 1994 dodge ram
diceteach is on a distinguished road
Unhappy Truck stalls after new drive belt?
It's a 94 dodge ram 1500 2wd 5.2 - A mechanic i'm not!! This is our third vehicle i purchased so i would quit borrowing trucks from friends. Everything was fine with this truck until I replaced the drive belt and battery. Now the idle is low (500 rpm) and it stalls under load when and only after it gets warmed up. Runs great when it starts up first thing in the morning. After it gets to operating temperature it starts to stall. Can a new drive belt screw things up like this? A new battery? (somehow messing with the computer system?)
I read the thread below and will look into vacuum leak and EGR valve. http://www.ramforumz.com/showthread.php?t=67666
Any advice will help. Thanks gang
Old 08-24-2011, 04:59 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Take a voltmeter and connect it to the batteries terminals and read the voltage with the engine running the voltage should be around 13.5 or higher with the engine running this will tell you what voltage the alternator is producing because the alternator voltage should always be higher then the batteries if the vehicle was off so anyways try that. I don't think this is much a alternator issue but just try it anyways because you state everything just dies and sounds like alternator could be it because if the alternator can't keep the battery charged then the battery would drain and then the voltage to the computer will be to low and the computer will cut power and wamm bamm good bye car stalls.
Old 08-24-2011, 05:14 PM
thank you RamVan2500, I will. I might add that when the new battery went in, pepboys checked the alternator and claimed it was fine.
Old 08-24-2011, 05:18 PM
ramvan2500's Avatar
Rep:128
Well their is an old saying " You want it done right, do it yourself" Well it's true, I had some tires mounted and didn't want to deal with installing the wheels myself this time and well they took the center caps off the wheels and they didn't put them on with all the mounting screws, they also didn't torque the lug nuts to 150 ft/lbs like they should have instead they torqued them 100 ft/lbs. I do all my own work but this time I wanted a brake so I just said ok let them do the fronts anyways, just check the voltage it's a good place to start remember to do it with the car on, if that all checks out then I can skip that electrical problem and look up some TSB's and see if their is a TSB then if not we can move to maybe a mechanical issue, Sometimes it's something simple like the Throttle body and IAC Valve need cleaning but it seems this stalling started after only a belt replacement and battery replacement however you can never be so sure.
Old 08-24-2011, 05:22 PM
It started immediately after the belt and battery change. Never had this issue beforehand.
Old 08-24-2011, 05:24 PM
ramvan2500's Avatar
Rep:128
Well first just check the alternator for the sake of it, if this checks out voltage should be around 13.5 or higher. If that checks out then your belt tensioner might be bad this is a common issue especially with vehicles around our age of 15,16 the tensioner and it's pulley gets hung up. Hey also check to make sure you router the belt properly also.
Old 08-24-2011, 05:35 PM
Just finished voltmeter check with neighbor, all ok. Also cut back battery wires and upgraded terminals. Belt is correct size and is on correctly no doubt. I will replace vacuum lines and clean throttle body next.
Old 08-24-2011, 05:38 PM
What has us stumped is that the truck runs great cold.
ramvan2500's Avatar
Rep:128
Ok after you try all this and still no good then check the belt tensioner like I said common problem. The worst of the worst in this issue would be that PCM had had it's days but I doubt that. I need you to do me a favor though I need you to look on the drivers side door pillar for the white federal sticker it will say the vin and tire pressure etc.. I need you to tell me what date the vehicle was manufactured so I can lookup the TSB's.
Old 08-24-2011, 05:43 PM
ramvan2500's Avatar
Rep:128
Ha ha, Runs great until up to temperature ok this pretty much is giving me an idea you do have a computer bound issue. I would probably first start with the air charge sensor that is screwed onto the intake manifold. Then check the coolant temperature sensor which is located on the left side of the coolant outlet housing on the block behind the accessories bracket. If the engine stalls out when it warms up then it's probably a faulty sensor of sort probably temperature but again clean the IAC Valve located on the throttle body this controls the air during idle and while driving until engine cools. You might just have a faulty sensor I know it would be odd of this because it only just started after a battery and belt but 1994 and well electronics don't last very long especially the IAC's those die after a while but I'm going to rule out as much as I can to help you.
dodge truck 1500 4.7
Want to keep your Ram rust free for years? Find out how, in here. ArmyofOne Dodge Ram Detailing and General Maintenance Forum 16 02-13-2014 01:27 AM
The third truck break in Seattle uktitus Off Topic Discussion 7 07-24-2011 06:00 PM
Truck dying- fuel pump? Please help :) thaduke2003 5.9L V8 Specific Topics 17 03-23-2011 10:05 PM
Returning member with 2nd truck - 1992 Dodge D250/350 w/ 5.9L Cummins Turbo Diesel Mavericke Newbie Checkin! 14 03-21-2011 10:19 PM
truck height 09 vs 11 2 wheel drive tnmopar Dodge Ram General Discussion 5 12-12-2010 07:52 PM
