Old 08-24-2011, 09:40 PM
HHOPPEERR HHOPPEERR is offline
Vehicle: 2001 dodge ram 1500
Color: silver
HHOPPEERR is on a distinguished road
Default front and rear end
hello i have a 2001 ram 1500 with the 5.2L.
my front end wont lock in but the transfer case does engage? the front end did work about a month ago.
the rear end make a strange sound when i make turns. but only on turns?
if anyone could help me on these items.
thank you.
Old 08-28-2011, 08:12 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Welcome to the site; I don't have an answer so, it's time to .................... this back to the top! Drop by the Newbie Checkin and introduce yourself. Hope to see you around!
Old 08-28-2011, 10:34 PM
Ty5.2magnum Ty5.2magnum is offline
Vehicle: 2000 Dodge Ram 1500
Ty5.2magnum is on a distinguished road
Ok guys this is my first post I have a 2000 single cab shortbed 4" lift 33s on 15s cold air and straight pipes its also a 5 speed has 3:55 gears I want the 3:92 gears will I need to switch front and rear axles off a dodge that has the 3:92 gears or just the rear?
Old 09-04-2011, 01:22 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
the noise in the rear end might be the clucthes locking up. they sell a synthetic stabliser that keeps them from binding up. add it to the fluid. drive it for a while then change the axle oil at the next service intervel. I think this is true for both axles. my brother had a 95 2500 4x4 that dose the same thing.
Old 09-11-2011, 10:50 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Hhopper, check fuses, your axle disconnect ain't connecting. Are you certain your t case is engaging? You getting a 4wd light? if not, yeah, I'd look into the axle disconnect, unplug and test whether or not voltage is at the plug... most lkely a fuse, I've popped mine many times, but being non-4wd season here for me, I can't remember all the associated symptoms, like what else quits when the fuse goes
Ty5.2, no fair hijacking someone elses thread... But yeah, running two different ratios will destroy the viscous damper in your t-case, or worse, as soon as you drive anywhere in 4wd.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
04 ram Hd 2500 what tire size with 2''kit front & rear? gear head Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 02-03-2012 10:08 AM
Complete Floor Lighting Front and Rear moose3 Custom Dodge Ram Interior and Exterior Lighting 8 07-11-2011 12:55 AM
Just Got My Build Sheet highlandchef 2009 Dodge Ram Forum 11 05-24-2011 05:12 PM
2009 Dodge Ram ST Crewcab 4.7 ?? sernul 2009 Dodge Ram Forum 16 02-19-2010 07:40 PM
