Dodge Ram Decals
Old 04-23-2010, 01:27 AM
progressionmotors progressionmotors is offline
progressionmotors is on a distinguished road
Default 2003 Ram Front End Knock over Bumps
I've heard a lot about the front end being trash on Dodge trucks. I just bought mine knowing that it is an achilles heel, and knowing that i'll be walking down a well beaten path.
So here I am looking for guidance...While going over bumps, I hear a knock/bump/bang from the front end, sometimes sounds repetitive (one bump in the road will initiated 2-3 knocks in RAPID succession...2-3 in less than .5 seconds).
I've heard a lot about ball joints, but haven't really tested mine. I raised the driver side front wheel, but it had zero play up and down. I've also heard a lot about sway/control arm ends, or whatever? I'm not good with front end issues, and this is my first 4x4.
If my above description is vague, here's what I experience. Driving down the road, BUMP *knock*....BUMP *knockknockknock*........BUMP *knockknock*.
Anyone have this problem?
Truck is a 2003 Quad Cab 4x4, 4.7L, 69K.
Old 04-23-2010, 10:53 PM
Rep:3322
I don't have an answer for you, but hopefully one of out tech guys can help ya out soon.
Old 04-24-2010, 07:17 AM
Rep:1915
1500, 2500, 3500? What year? Engine? T-case?
Old 04-24-2010, 08:19 AM
iRESQu iRESQu is offline
Rep:2217
While Randy is the man here, I thought I'd take this opportunity to say hello as I see you're a new member. Best of luck with your front end issue. Let us know how it turns out for you. Thanks and talk to you soon.
Old 04-24-2010, 01:59 PM
Rep:1625
Welcome to the forum! Glad to have you here! Keep us posted
Old 04-26-2010, 01:31 PM
jts2010 jts2010 is offline
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
jts2010 is on a distinguished road
I have a similar problem in my 92 ext. cab w/ Cummins. At least on my truck is sounds like something "light" - not necessarily "front end" strictly speaking. I've checked body mounts, engine mounts, battery tie down ect...
Sorry no help to offer just take comfort in knowing that we're a large group.
Old 04-27-2010, 12:05 AM
I appreciate the welcome! This is pretty much my dream truck! As far as specs, it is a 2003 Quad Cab 1500 with a 4.7L V8, 3.55 rear end with a manual shift transfer case (as opposed to the knob style). I believe it has the 5 speed transmission, but I haven't delved that far into it to know for sure. Only had it 1.5 weeks!
Old 04-27-2010, 07:23 PM
Rep:1915
You have the 545RFE transmission. You need to inspect the links and joints of the steering and suspension system. I would pay particular attention to the sway bar and shocks for that particular type of noise.
Old 04-27-2010, 09:55 PM
kevin amer kevin amer is offline
Vehicle: 2004 ram
Trim Level: laramie quad 4wd
Color: silver
kevin amer is on a distinguished road
i have the same noise in my 04 seems like its coming from under my feet lifted it on a hoist and found the torsion bars rattling in the mount under floor boards no real fix i just loosend off the adjuster screws and lubed that particular spot as wellas the front and the noise decreased quite abit but not totally gone hope this helps
Old 10-11-2011, 07:30 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
i had similar noise turned out to be sway bar end links like ram tech said. you should be able to shake them and hear the noise .
-PAT-
