Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Rust Repair
Rust Repair Fighting Mother Nature!
Old 08-26-2011, 07:52 AM
FF54 FF54 is offline
Vehicle: 1998 Dodge Ram
Color: Ford Woodland Green with black added
Rep:26
FF54 is on a distinguished road
Default Cab Mounts
Hey guys. haven't been on here lately due to work and workin on my ram. Just put new fenders on it last night and when i was underneath it doing the very bottom inside mounting bolt, i realized i have a very serious issue with the cab mount on the driver side front. Do they make a aftermarktet one to replace this? If not, has anyone here rebuilt one? Fabrication is no problem for me, i do alot of it, and i got a couple ideas on how I would go about doing it, but I wanna see what you guys have done first.
TIA
Old 08-27-2011, 01:54 AM
I haven't seen anyone who's done that here. Cab mounts are hard to find but if you can fab, that might be your best bet.
Old 08-27-2011, 01:57 AM
Rep:26
If someone could get me alot of pictures and measurements i know i could build them. do we have any takers for that?
Old 08-27-2011, 01:58 AM
If I still had my '99 I'd surely do it. Good luck!
Old 08-27-2011, 09:49 AM
Rep:26
Thanks Maddog, im sure someone will step up. Do you think that the front cab mounts would be the same on an extended cab and a standard cab?
Old 08-28-2011, 09:11 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 1997 Dodge Ram 1500 4x4 club
Color: Electric Blue
Rep:210
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Found your thread....here are the pics...
Mike
Old 08-28-2011, 09:17 PM
sonocativo's Avatar
Rep:210
11 inches long, 5 inches wide with a 6 inch support plate inside... it tapers downwards and flattens off as well as it tapers upwards geometrically and the end in compound radius'd so I dont really have anything to measure any of the angles or radius's..... Hope this helps somewhat... It is basically the mirror image of the opposite sides, these were pics of the passenger side.
Mike
Old 08-28-2011, 11:36 PM
Rep:26
i actually need it off the part that is attached to the cab. the part that is attached to the frame on my truck is good. its the part that is (was) one with the cab.
Old 08-20-2014, 12:57 PM
Dragonmyth Dragonmyth is offline
Vehicle: 1996 2500 Dodge Ram
Trim Level: 2500
Color: red silver
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Dragonmyth is on a distinguished road
Default Cab mounts repair
I am having the same problem as FF54. Can i buy the mounts or do I need to do a lot of body work?
Old 08-31-2014, 01:45 AM
KenBerry KenBerry is offline
Vehicle: 1995 Ram 1500 4x4 (5.9L)
KenBerry is on a distinguished road
Bumping this one back up because I've got a spot or two on my truck that looks just like the pic that Dragonmyth posted above.
Are there any options here other than maybe square steel tubing and a welder?
Motor mounts. oldseabee67 Cummins Diesel Specific Topics 3 12-07-2010 11:50 PM
Anyone use RAM mounts for their accessories? thewagon Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 11-08-2010 10:55 PM
Motor Mounts Replacement Question 4.7L 2WD tazsafety Suspension 5 09-15-2010 02:56 PM
Engine mounts 1999 3500 w/ 5.9 Cummins. oldseabee67 Cummins Diesel Specific Topics 1 08-05-2010 04:18 PM
