Old 08-26-2011, 07:41 AM
scooper77515's Avatar
scooper77515 scooper77515 is offline
scooper77515 is on a distinguished road
Default What is needed to put 6.1 hemi into 5.7 truck?
I doubt it is a direct swap. So what "extra" parts are needed to make it fit?
Keeping stock transmission and everything else.
Old 08-26-2011, 08:55 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I be its all electrical/sensor related. You would need a naw CAI because of the forward facing TB instead of the upward pointing TB.
Im sure there is more, that is just what i could think of off of the top of my head. I bet the engine mounts and trans pattern is the same
2011 Big Horn 4x4 -SnowWhite-
Old 08-26-2011, 11:00 AM
williamhartle's Avatar
williamhartle williamhartle is offline
Vehicle: 2007 dodge ram
Trim Level: st
williamhartle is on a distinguished road
yah id imagine its all electrical possibly new computer or something along those lines
2 inch leveling lift 3 inch body lift, 34" bfg mud terrain TA KM2, straight pipe, vararam intake, superchips cortex, Firestone air bags, skyjacker n8000 shocks rear, s8000 front struts, painted head lights, tinted tail,cab mount light, big shiny chrome balls.
Old 08-26-2011, 02:08 PM
Hmmm. I figured it would be wider needing different motor mounts, maybe a transitional plate at the trans to line the bolts up, etc.
Has anyone done it?
Old 08-26-2011, 02:36 PM
Rep:2597
you should start here
http://www.thehemi. com/newhemiswap.php
the address is separated, you need to reconnect it
Old 08-26-2011, 04:09 PM
you sent me to that link in another question I asked, and it mostly talks about putting a newer 5.7 or 6.1 into an older car, even non-Mopar cars.
I would think slapping a 6.1 into a stock 5.7 car would be easier than putting a 6.1 into my Ford Maverick, or other older car.
Old 08-26-2011, 04:39 PM
Rep:2597
i may have given you that address before, but did you try contacting any of those companies mentioned to see if they have any insight as to a 5.7 to 6.1 swap?
i Googled a swap, could only find a post from 2006
10-02-2006, 05:25 PM no srt-8 in the future of the rams. i'm subcontracted put though roush for chrylser and do alot of ORVT, along with lexus and toyota.
as far as the swap, the 6.1 and 5.7 are the same basic motor, just the 6.1 is bored out, with different heads and a HUGE intake manifold with some big ass runners. you will need to modify the hood of the truck to het the heighth correct. as far as the motor mounts, im pretty sure they will be the same, but some cutting and welding should fix that up if need be. and for tranny, that im not too sure about. if you ahve a shortbed, shortcab, id go with a full srt-8 swap out of a charger for rwd, or super-skittle(grand cherokee) for awd, but the awd may be more work than worth.
your main problem is goin to be computers. the 5.7 hemi that is out now has a totally different computer that the 6.1(just wait till the next gen 5.7 comes out) the srt-8 motor has about 11 seperate computers(pcm, ecm, abs, etc etc) whereas oyour 5.7 has 5, i think.
IMHO, get an SKS aft turbo kit with intercooler, cam the motor, long tubes, port the heads, and get an ecm flash. youll be at an easy 500-550 rwhp. then if you feel the need, throw on a sneaky pete 75 wetshot. trust me, ive looked into a 6.1 swap a lil, and with my experience with workin on these motors all the time, pullin, installin, workin and flashin them, i know what im talkin about.
Old 08-26-2011, 05:26 PM
Thanks! That is the kind of info I was looking for!
I am not looking for more power, but if my 200k motor decides to give up the ghost in the next couple years, I was wanting to know what my options are. If the 6.1 was an easy swap, I would look into it more seriously. But the hood and intake issues alone are way more than I would want to do.
A .030 over 5.7 might be all i need. And I could do that myself. If i didn't care about losing my daily driver for a few weeks while I order parts and rebuild it.
The 360 hp or so I have now tows my boat just fine, and still pull 22 mpg on highway (not while towing, of course!).
Old 08-26-2011, 11:15 PM
Hmmm. Sneaky Pete...
I have a 150 shot on my maverick. It wouldn't be all that hard to mount the solenoids on my intake and give the 5.7 a little boost!
Would I need to mount both the fuel and nitrous solenoids, or would the fuel injection kick in and keep the fuel ratio up on it's own just squirting in the nitrous.
Just asking for a REASON to HAVE to swap the engine, now.
There is no way I would do this to a 200k mile engine on a daily driver.
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 207 06-07-2013 09:30 AM
HEMI vs F 150 ECO BOOST E220 2011 Dodge Ram Forum 512 03-12-2013 10:42 AM
FIRST TRUCK EVER 05 Ram 1500 qc Hemi RAMBUSA Newbie Checkin! 12 01-23-2011 10:14 PM
New 2010 Hemi Rough Idle jimw 5.7L (345 cu in) HEMI V8 Specific Topics 3 06-20-2010 01:07 PM
new to forum got a new truck (03 5.7 HEMI) check it out agood6000198 Newbie Checkin! 12 06-08-2010 01:12 PM
