Old 08-26-2011, 10:28 PM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
Default Anybody run a 1/2" wheel spacer on the 2011 RAM???
I'm looking at getting just a bit more space out of mine and try and squeeze a 305/70/17 on my rig when I get tires next. I put on some Vision Warrior 375's on it and I really like the look, but I feel like if I go any bigger on the tires, they're going to rub. There was not much clearance when I turned the wheel lock to lock especially if I end up airing down at all. I was going to try 1/2" wheel spacers and want to get a quality hub-centric spacer that will work well with a 2011 specific truck. Has anybody on here tried one and with what luck was it that you tried it??? Thanks in advance.
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
Old 08-26-2011, 11:35 PM
williamhartle's Avatar
williamhartle williamhartle is offline
Vehicle: 2007 dodge ram
Trim Level: st
williamhartle is on a distinguished road
not trying to dis ur truck or anything but do u really want to put that large of tire on with the 4.7??
2 inch leveling lift 3 inch body lift, 34" bfg mud terrain TA KM2, straight pipe, vararam intake, superchips cortex, Firestone air bags, skyjacker n8000 shocks rear, s8000 front struts, painted head lights, tinted tail,cab mount light, big shiny chrome balls.
Old 08-27-2011, 12:03 AM
bigred0603's Avatar
bigred0603 bigred0603 is offline
Vehicle: 2005 Dodge Ram 1500
Color: BLUE
Rep:38
bigred0603 is on a distinguished road
I got spacers on my truck had and issue with the rim not laying flat on spacer causing wobble after inspection found the truck studs were too long and didn't allow the rim to lay flat after shaving the studs no more issues love the look I got an 05 though
Old 08-27-2011, 09:57 AM
cyberpine cyberpine is offline
Vehicle: 2010 Dodge Ram Quad Cab Hemi
Rep:53
cyberpine will become famous soon enough
did you do this? I have a 2010 Quad Hemi 4x2 stock suspension and I had a set of (4) 1/2 inch thick machined aluminum spacers made, but am yet to try them out. studs look long, but suspect i will only get 5 turns with them on. I'd like to fit some 325/50/20s (~13x32) on my stuck 20x9 +19mm offset chrome clads. I've seen it on a 4x4, but never a 4x2 with no level or lift. I might be the first to try, but an expecsive test. Also concerned about fuel economy just for an aggressive look. But do think 325/50/20 would look awsome on my truck.
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 08-27-2011, 11:19 AM
bombadillo's Avatar
Rep:25
Yup, people put 37's on a ford ranger with 3.73 gears and a little 2.5 liter 4 banger so I figure the 4.7 could swing some 34.5" tires with ease in comparison. It really isn't that big of a difference, the factory tires are about 32.5" or so, so I'm only really adding a couple inches.
Careful, they're hub-centric wheels and if not centered properly you'll get wobbles like crazy. I have heard you need 7 full rotations on the lugs to get them to seat and torque properly. That may or not be enough, but thats just reading here on the boards so take it for what its worth.
Haven't done it yet. Wow though, those are going to be some big friggin tires on that. You may still run into some rubbing with a tire that big.
Old 08-27-2011, 02:18 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I had 1/2" spacer on a 2500 with 4 turns on the lugs, wasn't crazy about them and they still rubbed anyway so I have 1.75" spacer now so I didn't have to trim the factory lug, not really the best way to go either but it's been 20k miles with out problems
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
1/2 inch wheel spacer on 2010 4x2. Longer Wheel studs? cyberpine Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 23 08-12-2011 05:53 AM
Wheel hop! sprintertech Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 02-06-2011 10:40 PM
