Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 08-27-2011, 12:21 AM
XaeLee XaeLee is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman
XaeLee is on a distinguished road
Default PROBLEM: says 'Key In Ignition' but it's clearly not
So when I park and turn off the truck, then pull the key out, it says "Key in ignition" when it's clearly not. When i step out of the truck and close it and try to lock it with the remote, it wont lock.
things i tried:
-turning on the ignition again and then removing the key again
-poking random pins in the key hole
So i would have to lock the doors before turning the car off... then manually lock the drivers door when i leave the truck. Do i have to bring this to the shop or is this a problem someone might know how to fix that i can try?
Thanks!!
-Andy
Old 08-27-2011, 12:29 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I think a trip to the dealer is in order, but you should be able to lock the truck with your other FOBIK. Since they have different 'codes', it will recognize it as being out of the truck ans should allow it to lock the doors. I know with mine, I can get out of the truck with the FOBIK in the ignition, and lock the doors with the other one.
brad
Interested in one of my mods?
Old 08-27-2011, 12:31 AM
ahh.. darn =P
unfortunately i only have set of keys (fob with key in it, and just a manual key)
Old 08-27-2011, 01:03 AM
brad12kx's Avatar
Rep:2581
Originally Posted by XaeLee View Post
ahh.. darn =P
??? Seriously ???
I though all trucks came with 2 FOBIKs from the factory.
brad
Old 08-27-2011, 01:06 AM
Yeah, there is a problem in the ignition lock cylinder. It may just be a stuck tumbler.
Ignition Switch and Fan Blower Problem steelman512 Electrical 13 09-22-2013 08:54 PM
Ignition problem andrewdains Electrical 2 05-22-2010 03:35 PM
Key Ignition Problem andrewdains Electrical 3 03-17-2010 10:38 AM
Changed ignition switch now alarm system problem ineedabin2 Dodge Ram General Discussion 1 07-08-2009 07:58 PM
04 Ignition Problem MTobe Electrical 0 05-29-2009 02:25 AM
