Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
tonneaucovered.com
Old 08-27-2011, 12:17 AM
Mudder's Avatar
Mudder Mudder is offline
Vehicle: 2012 Jeep Wrangler
Trim Level: Unlimited Sport
Rep:40
Mudder is on a distinguished road
Default Rattle in dash?
I have got a rattle somewhere in the cab of the new truck. Best I can tell its coming from the center of the dash toward the windshield. I've looked at the center speaker, and things up there and none of those seem to be the culprit. You can hear it when you shut the door and then over any bumps. It's annoying the hell outta me. Wondered if anyone had had similar experiences? I've check the screws on the door panels, made sure it wasnt something in the glove box, seat belts etc. Not sure what else it could be.
Old 08-27-2011, 12:48 AM
Rattles and squeeks are the hardest thing to track down. Make sure your defroster panel is fully seated.
Old 08-27-2011, 12:52 AM
Mudder's Avatar
Rep:40
Yeah, checked that and the trim covers on the dash. I don't mind the squeaks every once in a while cause heck, its new, but the rattle is making me lose it. I've got an appointment with the dealer next week but I'd of course like to fix it myself.
Old 08-27-2011, 12:56 AM
Yeah...it's hard to track these down, even for the techs.
Pull your lower dash panel off on the driver's side and make sure your wiring harness and misc. wiring is not banging on the back of a panel.
Old 08-27-2011, 12:58 AM
Mudder's Avatar
Rep:40
I'll tell you what it sounds like, cause I knew id heard similar but couldnt put my finger on it. It sounds like a spray paint can, the little steel ball in there when you shake it and then it settles back down to the bottom.
Old 08-27-2011, 02:17 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
If you like me and bound and determined to fix it yourself, then you have to start tearing the dash apart. Start with removing the trim and test for rattle, then the radio, test again, etc...etc. Eventually you will either find the rattle or bring the truck to a non-functional state ....but either way, you will then know how everything comes apart.
brad
Interested in one of my mods?
Old 09-18-2011, 08:34 PM
jonnyriabov jonnyriabov is offline
jonnyriabov is on a distinguished road
The windsheild defrost tubing is in the shape of a T. The foam at the top of the tube where it connects with the vents is put on too low from the factory. Its a real pain to fix. I found the easiest way is to put closed cell foam between the dash and the T shaped vent, the fix only lasts about 6 months before it returns and you need to fix it again.
The best way to tell if this is your problem is the push down on the dash next time you hear it. If the noise goes away, you found it
Rattle in dash gjayf77 2011 Dodge Ram Forum 36 03-22-2015 12:20 AM
Rattle in dash tnmopar Body & Interior 42 09-18-2012 07:14 PM
squeek under the dash and rattle from columb redneck107 5.7L V8 Specific Topics 1 08-19-2011 10:38 PM
1994 CTD Dash Replacement johnny0874 Body & Interior 15 04-09-2011 10:22 PM
97 1500 Dash Replaced! brewman Dodge Ram Knowledge Base 3 02-05-2011 02:41 AM
