Old 08-27-2011, 05:06 PM
HarleyRam's Avatar
HarleyRam HarleyRam is offline
Vehicle: 2011 Dodge Ram
Trim Level: SLT Big Horn 4x4
HarleyRam is on a distinguished road
Default Cargo Light TIPM trigger wire
Does anyone know what wire triggers the cargo lamp on at the TIPM? I installed Amp-Research Power Steps and liked how it uses the door ajar wire on the TIPM to activate the step motors. I want to install bed lights and use the cargo lamp wire at the TIPM to turn them on. I do not want to add a switch in the bed. Even though they are led's I will still be using a relay. I don''t want to run wires into the cab. I tried to use the link I found on the forum for the TIPM, but I couldn't figure it out. I called Amp-Research to see what wiring diagram they use and they were no help. Thanks in advance for any and all help.
Old 09-01-2011, 09:09 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I don't have an answer for you so I'm gonna the post.
In addition I need to say "Hi" and a warm Carolina welcome to the best RAM ForumZ on the web. I'm here to help you navigate the site so how about jumping over to the Newbie Checkin and introducing yourself?
Old 09-02-2011, 12:24 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The wiring for the cargo lamp does NOT originate from the TIPM, but rather the Instrument Cluster. Unfortunately, all the wiring for it is in the cab.
If you do venture to wire into the cab, it is on connector C1 terminal 3 (White/Tan)
brad
Interested in one of my mods?
Old 09-05-2011, 01:53 PM
HarleyRam's Avatar
Thanks for the bump FastEddie. Thanks for the info Brad. Guess I'm gunna run a wire in there.
Old 09-08-2011, 11:46 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Why not just tap into the led lights on your amp steps? when they come on (door open) your beds lights come on
Old 06-09-2013, 12:20 AM
MXMagnum's Avatar
MXMagnum MXMagnum is offline
Vehicle: 2012 Ram 1500
MXMagnum is on a distinguished road
Searched the site because looking to do the same on my 2012. HarleyRam, how did it work out running into the cab? Was hoping to go to TIPM like I did for remote tailgate lock, but that's not the case here. Don't want to mount switch in bed or cab, thought cargo lamp would be best, then lights don't get left on by accident. Any other options or ideas?
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 08:19 PM
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
How To: "Big 5" Basic Engine Re-Wiring Upgrade - Tutorial Valldar Dodge Ram Knowledge Base 24 05-24-2014 04:39 PM
HID INSTALL SOLUTION for anyone that cares silverbullet13 Custom Dodge Ram Interior and Exterior Lighting 3 08-26-2013 08:54 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
