Dodge Ram Decals
Old 10-13-2011, 03:23 AM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
quick exhaust clip and walkaround
Old 10-13-2011, 09:49 PM
mr.lopar's Avatar
Rep:192
been cleanin the garage all week and i came across a couple hood pins today. gotta get a couple scuff plates and pins now and paint em black since they're pretty beat up. these will be temporary till my next order with jegs
the money i got from the scrap i hauled in the other day i went and bought a few things (head gasket set, 180 t-stat, bypass hose, oil and filter)
look at the intake before the planum pan went on, cut the runners down and smoothed out the edges
i also gasket matched the intake while i was at it
180 t-stat and gasket installed
intake ready to go on
started workin on the heads today, already gasket matched the intake side, started pullin valves to replace seals, and gasket matching the exhaust ports
Old 10-14-2011, 09:00 PM
mr.lopar's Avatar
Rep:192
well i ended up completely dismantald the head, gonna do the other head tomorrow
after i finished smoothin everything out and lapping the valves, i installed new seals
and reassembled
Old 10-15-2011, 12:51 AM
mr.lopar's Avatar
Rep:192
video while i beat on it a lil
Old 10-16-2011, 08:23 PM
mr.lopar's Avatar
Rep:192
not much of an update, but the heads are cleaned, assembled, and painted. i painted em with rustoleum high temp flat black but dont like how they look so im gonna get a can of gloss black and do the headers in flat black
Old 10-22-2011, 12:15 AM
mr.lopar's Avatar
Rep:192
yay lil bit of an update, got the heads painted semigloss black, look much better, also threw in new frost plugs since i was there, and reinstalled 6 of the 8 plug tubes, gotta take two off my truck. gotta go work on the 5th tomorrow and move it over at my buddies house, so i might start tearin into the motor on sunday,,,hopefully, i think i have everything i need now,,,i think
Old 10-23-2011, 02:07 AM
mr.lopar's Avatar
Rep:192
well i started tearin into the motor today, if it dont rain tomorrow it should hopefully be up and runnin tomorrow night or monday morning
since i had to drain the coolant, i looked at the petcock, and saw iff i opened it up, it would go all over the frame rail, and run down onto my skid plate and sit in there, and there was now way i was takin that off as its mounted under the sway bar, so i looked around and found my trans funnel, wedged it up in there down to a drain pan, and wah-la, not a drip on the frame or the ground
started the tear down, woulda got more pics, but it got dark out, but the right side header it off, intake is off, swapped out the left valve cover so i could paint it, a/c and bracket is removed, power steering pump is off, and any other lil misc things.
couple of the brackets and some bolts painted, was gonna take pics, but the phone died. got both valve covers,fuel rail, right side header,throttle body bracket and coil bracket painted also
Old 10-23-2011, 09:39 PM
mr.lopar's Avatar
Rep:192
didnt get much done today as it rained most of the day till about 5:30ish. but i got the intake pulled and the right side head. pulled the belt tensioner pully off the right head and painted the bracket part of it. put the valve covers together, and got the intake assembled
new and old intakes
heads with matching valve covers and 1 painted header
Old 10-24-2011, 09:16 PM
mr.lopar's Avatar
Rep:192
heres what i went out to this mornin
so i put on the right side head
so i replaced the left side head, when pullin the header off the damn thing fought me all the way, first the collector bolts were stiff all the way, and one broke, then one the middle studs for the header wouldnt come off, 7/16" wrench was too small and 12mm was too big, so i ended up taking a hammer and chissle to it
also ground down the welds on the inside of the headers for a lil bit better flow
also got the intake and valve covers back on, but again it got to dark for the pics to turn out
Old 10-24-2011, 09:26 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Cool video man, looks like fun.
Dillon-aka, The Little Kid
Black Mamba's Mod Thread Juice420 Custom Dodge Ram - Complete Builds 79 11-06-2012 10:34 AM
The Codes Mod Thread The Codes Custom Dodge Ram - Complete Builds 52 04-08-2012 05:39 PM
*Moddin' on a Budget*---The Ultimate Cheap Mod Thread... ArmyofOne LD RAM - General Discussion 48 11-18-2011 01:19 AM
916Timmy: Mod thread!!! 916Timmy Custom Dodge Ram - Complete Builds 49 09-19-2011 09:57 PM
Another Exhaust Mod Thread tdub2112 5.9L V8 Specific Topics 6 03-22-2011 09:17 PM
