Old 08-28-2011, 12:59 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Default Mod16 - Cabin Air Filter
NOTE - This mod applies to 4th Generation Rams Only!
Today I had a half hour of 100% free time. Not long enough to clean the truck, so decided to do a mod instead.
Cabin Air Filter
Here are the Dodge Avenger parts that were used.
I started by emptying the lower glove box, then squeeze the sides in to release the tabs that stop it from falling out.
Just lift up slightly and out it comes.
Looking in though the hole you will find the airbox with an outline that matches the cabin filter cover for an Avenger. When cutting out, stay inside the raised rib.
This next part is optional, but I find that removing the fan to be able to reach inside is very helpful in removing the piece you cut out. Here is what the fan assembly looks like when in position. I had already removed the back screw before snapping the pic.
Here I have marks the 3 screw locations. They remove real easy with a 5/16" nut driver. Don't forget to unplug the fan motor wiring.
About 20 seconds later, the fan is out. Hmmm....I wonder what the flat rate is to replace this item......
Here is looking up into the airbox where the fan normally sits.
The air box modification tool of choice.
This is the plastic after removal. I find it easier to cut straight across the bottom and remove/optionally remove the the small lower tab. It is completely unnessessary to remove this small lower tab, but the embossing is there, so I just couldn't leave it. No one will every see it, but 'I' will know it's there...
Here is the opening after all the knife work is done.
To Be Continued.......
brad
Interested in one of my mods?
brad12kx's Avatar
Rep:2581
Time for the filter (p/n 05058693AA) . I'm sure they could have found a bigger box.....but....maybe not.....
Taking careful note of the air flow direction arrows, install the filter. It just slides in, and sticks out a bit (~3/4"). It's a little tricky to slide in, as the hole is partly blocked by the dash. I only took about 10 seconds of patience to slip it in with any damage.
Next, the cover (p/n 68052292AA).
Slip the cover in place, and press the 2 end tabs toward each other. They will 'click' once in place.
Put the fan back in (about 30 seconds) and this is what it should look like.
Here is comprhensive list of tools.
This mod took a total of 25 minutes. Had I not stopped to take pix, it would have been between 10 & 15 minutes.
Couple of items of note -
1) Make sure you have 'sharp' knife with a good point. I DO NOT remommend using a knife with break-off blades (even the HD version). You will be putting a fair amount of pressure on the knife, and a break-off blade would likely lead to injury.
2) Went cutting out the plastic, cut the bottom first, then the top. If you cut the top first, there is nothing substantial to hold the bottom, so there is some (not a lot, but some) risk of breaking the housing.
3) With the fan removed, you can easily reach inside to puch the plastic piece out. Wit the fan in place, you may end up droping the piece into the fan, and will have to remove it anyway, so for the 60 seconds it takes to R&R, it's well worth it.
brad
Old 08-28-2011, 01:29 AM
wolfman10's Avatar
wolfman10 wolfman10 is offline
Trim Level: SLT- Lonestar
Rep:188
wolfman10 has a spectacular aura aboutwolfman10 has a spectacular aura about
Great write up! How much did the mopar parts run?
-Cody
My Build: http://www.ramforumz.com/showthread.php?t=86853
Old 08-28-2011, 01:39 AM
brad12kx's Avatar
Rep:2581
Total cost was $45/00 taxes included. The cover is the cheap part...$11.
brad
Old 08-28-2011, 01:50 AM
wolfman10's Avatar
Rep:188
Cool! That maybe a mod in the future for me!
-Cody
Old 08-28-2011, 02:47 AM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Know did you do this becuase these rams dont have a cabin filter? or because its easier to maintence?
Old 08-28-2011, 03:02 AM
brad12kx's Avatar
Rep:2581
Little of both. In the fall, my Hay Fever drives me nuts, so have always installed some sort of cabin air filter in my trucks. Also, I like to keep my truck clean inside and out, and a cabin air filter sure helps reduce the interior dust. In the case of the 4th gen Rams, this is such a great way to filter the air, as it also filters the re-circulated air when the AC is on max. The only 'difficulty' in changing the filter, is you have to remove the lower glove box, but that only takes 10 seconds....so not too big of a deal.
brad
Old 08-28-2011, 10:46 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Great write-up sir!!! This is a good idea for any 4th gen owners.
Old 08-28-2011, 11:15 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Have the cover, just need a filter!
Old 08-28-2011, 01:23 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Nice mod brad! Seems simple enough.
Dillon-aka, The Little Kid
Add Cabin Air Filter to 4th Gen for less than $20 HoustonHemi Custom Dodge Ram Interior Modifications - Custom Audio / Video 198 07-22-2015 02:44 PM
Air Cabin Filter larryibc Heating & Cooling 3 08-29-2011 11:33 PM
Cabin air filter workhorse Dodge Ram General Discussion 1 08-17-2011 12:59 PM
Cabin Air Filter Mod ciara Heating & Cooling 1 07-01-2011 12:55 AM
