Old 05-31-2013, 12:30 AM
bigolyt bigolyt is offline
Vehicle: 2013 Dodge Ram
Rep:43
bigolyt is on a distinguished road
And now I cancelled it because it was back ordered
I did pick up the parts from the local dealer though for cheaper.
On a side note, I checked out the location, it seems like there's something already inside that area, is there a way to check that nothing is behind that piece Im about to cut out?
Old 06-01-2013, 11:21 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
There is nothing there to worry about. If you still need to test it first, remove the fan motor assembly, drill a tiny hole through the stop your going to cut out and reach through the fan hole to feel the drill bit.
brad
Interested in one of my mods?
Old 06-01-2013, 08:08 PM
Mopar Big Horn's Avatar
Mopar Big Horn Mopar Big Horn is offline
Vehicle: 2011 RAM 1500 crew cab 2wd
Color: PR4 Flame Red
Rep:148
Mopar Big Horn will become famous soon enoughMopar Big Horn will become famous soon enough
Like everybody else has said, good write-up brad12kx! Seems like a easy mod and a very much needed mod. I believe I'm going to have to get these parts ordered so I can add this. Good pics and descriptions, Rep pionts for that!
Check my mod list.
Old 06-01-2013, 11:52 PM
brad12kx's Avatar
Rep:2581
Thank you for that!
I think this still qualifies as my favorite mod as it is low cost, easy to do AND makes a noticeable difference.
brad
Old 06-12-2013, 09:58 AM
jimwww's Avatar
jimwww jimwww is offline
Vehicle: 2012 1500 Sport Crew Cab
Trim Level: SPORT
jimwww is on a distinguished road
Send a message via Skype™ to jimwww
First mod I will do - very nice write up thanks.
BFG A/T 275/60's - 20 inch wheels, Extang Solid Fold Tonneau. K&N Filter.
Old 06-18-2013, 06:22 PM
The Crow 1994's Avatar
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:56
The Crow 1994 will become famous soon enough
Can't wait to do this mod this weekend. My cabin air filter kit just shipped from Geno's Garage. It had been backordered for a little while.
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
Old 06-19-2013, 01:10 AM
brad12kx's Avatar
Rep:2581
Don't wait for the weekend. Only takes a few minutes and your lungs will thank you.
brad
Old 07-08-2013, 04:02 AM
Foxtrot Foxtrot is offline
Vehicle: 2013 Ram 1500 Big Horn
Trim Level: SLT - Big Horn
Color: Maximum Steel Metallic
Foxtrot is on a distinguished road
I just did this on my 2013. I had problems with the cover plate not being able to clip into the slots. I had to secure it with a small piece of duct tape. Anyone else notice this problem?
Old 07-08-2013, 08:42 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Not at all if you didn't get it to clip in correctly you should go back and check your work, you may have missed a piece of the plastic and not cut it correctly just double check your edges. It should sit in there nice and snug not duct tape needed.
Old 07-08-2013, 10:15 AM
Asur Asur is offline
Vehicle: .
Rep:4373
the clips are hard to get clipped, clip it on the passenger side first, then you have to clip the driver side, you will need small fingers (or a flat screw driver)to push the clip up on the pin for it to clip properly, the second time when I changed my filter it seems the clips take shape and clips up right away.
Add Cabin Air Filter to 4th Gen for less than $20 HoustonHemi Custom Dodge Ram Interior Modifications - Custom Audio / Video 212 01-14-2016 10:34 AM
Air Cabin Filter larryibc Heating & Cooling 3 08-30-2011 12:33 AM
Cabin air filter workhorse Dodge Ram General Discussion 1 08-17-2011 01:59 PM
Cabin Air Filter Mod ciara Heating & Cooling 1 07-01-2011 01:55 AM
