Old 09-24-2013, 08:26 PM
AlbertaRAM92's Avatar
AlbertaRAM92 AlbertaRAM92 is offline
Vehicle: 2012 Dodge Ram
Rep:43
AlbertaRAM92 is on a distinguished road
Just finished this mod on my 2012 Sport. Great right up!! Doing my dads longhorn next.
2012 Ram with a black green theme. Open to ideas on how to make her better.
Old 10-26-2013, 09:47 AM
wmorris4x4's Avatar
wmorris4x4 wmorris4x4 is offline
Vehicle: 2013 Ram 1500 Sport 4x4 5.7
Color: 1ea Bright CherryRed 1ea White
wmorris4x4 is on a distinguished road
I just instl 2 of these in the wifes and my trucks, along with the upper glovebox door assy. took 1hr for wifes for both instl, filter door cover was a bitch to get latched, mine i cut out with zip tool and was lot faster, cover just snaped into place on it, about 30min for both instl on my truck. Went with blk on both from AllMoparParts
Filter kits 23.43 ea
Blk Glovebox assy and hardware 83.23 ea
Old 10-31-2013, 01:56 PM
whiteknight312 whiteknight312 is offline
Vehicle: 2012 dodge Ram Bighorn
Trim Level: big horn 4x4
whiteknight312 is on a distinguished road
I used the Purolator myself. the writings on the opposite side you need to insert into the opening, but all is good. went in ok. the latch on the door did not work well until I had it really pushed closed.
I cannot believe that dodge did not make this factory!! its all there, so why not make this stock?????
I remember when I had a titan. Nissan used 2 small filters and the cost was double! and you stacked them up??
cheers for telling us about this!
Chris
Old 10-31-2013, 02:32 PM
wmorris4x4's Avatar
Chris
Same here, cant believe they didnt instl as factory unit. i did trim a bit more out on my truck and smoothed it up, dont know if that made the diff in ease it went on as opposed to wifes PIA , not looking fwd to hers being changed, might have to trim on it a bit more.
Old 11-07-2013, 08:29 PM
Alaskan Alaskan is offline
Vehicle: 2009 Dodge Ram 15004WD Laramie
Color: Sunburst Orange
Alaskan is on a distinguished road
Will this mod work with a 2009 Dodge Ram 1500 4WD Laramie?
If so, what is currently best recommended parts list and vendor to purchase/order from? :-)
Thanks!
Old 11-08-2013, 12:36 AM
wmorris4x4's Avatar
it should work on the 09, i got mine at Moparparts came with filter and panel closure for 23.42
Old 11-10-2013, 05:15 PM
astonius astonius is offline
Vehicle: 2014 Ram 1500
Trim Level: Laramie Limited 6'4"
Rep:30
astonius is on a distinguished road
Just finished this mod on my '14, and I've gotta say it was a b*tch! I tried using a utility knife at first, but I just could not get enough force behind it, so I ended up using a Dremel to cut and then sand the edges. It took me a couple of hours. Removing the fan was necessary, as quite a bit of melted plastic from the Dremel would have fallen into it anyway. I used the Wix filter, so the writing for air flow direction is on the left side instead of the front as pictured, but it slid in without issue. The door slides on and sits flush with the box, however the snaps on the sides do not lock into place. I'm not too worried about it as I don't expect it to slide off or anything, but I don't know why it won't snap.
Aside from my difficulties, this write-up is great. Thanks OP!
Old 11-12-2013, 05:08 PM
Tanker4lyfe Tanker4lyfe is offline
Vehicle: 14' RAM 1500 CC SPORT 4X2
Trim Level: 1500 CC Sport 4x2
Color: Granite Metallic
Tanker4lyfe is on a distinguished road
I will be doing mine this weekend! thank you
14' 1500 CC Sport 4x2: Green Filter, Geno's Cabin Filter Mod, DeeZee TG Assist, Line-X, HuskyLiners
Old 11-16-2013, 05:17 PM
stefanAT's Avatar
stefanAT stefanAT is offline
Vehicle: 2012 RAM 1500 4x4 QC
Rep:13
stefanAT is on a distinguished road
Don't worry, the snaps didn't snap in as I did the mod on my '12, but it never was a problem. I changed the filter a year after I did the mod an the door was still perfectly in place. So the missing snap noise is nothing I worry about.
Old 11-23-2013, 07:02 PM
MN13Laramie's Avatar
MN13Laramie MN13Laramie is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Copperhead
Rep:43
MN13Laramie is on a distinguished road
I did get mine to snap, but I really had to clean up the cut edge to make sure no little pieces of plastic were holding the door out just a little bit, then I really had to push on the latches on the ends to get it to snap. I'm part of the Murphy club on this one as it took an hour or so, but glad I did it in the end! Thanks for the work on the procedure!
Mike
Mike
2013 1500 - Copperhead
Add Cabin Air Filter to 4th Gen for less than $20 HoustonHemi Custom Dodge Ram Interior Modifications - Custom Audio / Video 180 01-18-2015 01:47 PM
Air Cabin Filter larryibc Heating & Cooling 3 08-30-2011 12:33 AM
Cabin air filter workhorse Dodge Ram General Discussion 1 08-17-2011 01:59 PM
Cabin Air Filter Mod ciara Heating & Cooling 1 07-01-2011 01:55 AM
