Mod16 - Cabin Air Filter - Page 26 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 03-14-2014, 05:36 PM
firefighter830 firefighter830 is offline
Vehicle: 2013 Ram 1500 Sport
firefighter830 is on a distinguished road
Just finished this on my 13 Sport...had some trouble getting a clean cut on the hole and mine was a little to the right of the glove box making it a little tough to get the filter in the slot....but anyway its done and I'm happy...I bought the Fram CleanBreeze filter since it was carbon activated.
Old 03-15-2014, 03:54 PM
514RAM's Avatar
514RAM 514RAM is offline
Vehicle: 2013 DODGE RAM SPORT QC 4X4
Trim Level: SPORT
Color: BLACK
514RAM is on a distinguished road
Little of both. In the fall, my Hay Fever drives me nuts, so have always installed some sort of cabin air filter in my trucks. Also, I like to keep my truck clean inside and out, and a cabin air filter sure helps reduce the interior dust. In the case of the 4th gen Rams, this is such a great way to filter the air, as it also filters the re-circulated air when the AC is on max. The only 'difficulty' in changing the filter, is you have to remove the lower glove box, but that only takes 10 seconds....so not too big of a deal.
Thanks Brad12kx... i have the same problem, i will definitely do this mod in the spring!
Old 03-22-2014, 11:50 PM
Superduper Superduper is offline
Vehicle: 2013 Crew Cab
Superduper is on a distinguished road
Did this today. Great write up.
Old 04-08-2014, 08:22 PM
Fakinrite's Avatar
Fakinrite Fakinrite is offline
Vehicle: 2010 Dodge Ram 5.7L Crew
Fakinrite is on a distinguished road
Installed my cab air filter tonight, was a piece of cake thanks to Brad's write-up.
Maybe, just once, someone will call me 'Sir' without adding, 'You're making a scene.'-Homer Simpson
Old 04-10-2014, 11:18 PM
ksarnecki's Avatar
ksarnecki ksarnecki is offline
Vehicle: 2013 Dodge Ram 1500 4x4
Rep:29
ksarnecki is on a distinguished road
Just did this mod last week. Helps with the allergies. Got a cheap kit off eBay and used my Dremel, only took 10 mins. Thanks for the write up!
Old 04-23-2014, 09:55 PM
my87csx481 my87csx481 is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT regular cab
my87csx481 is on a distinguished road
Thanks a lot for posting this.
Did it about a week or so ago. Allergies haven't kicked in yet where I'm at but, hopefully this helps some.
Old 05-21-2014, 12:14 PM
sll00's Avatar
sll00 sll00 is offline
Vehicle: 2014 ram sport
Trim Level: sport
Color: GCM
Rep:29
sll00 is on a distinguished road
Default 2014
Great post. Ordering now. Is the 2013 air filter are same size as 2014? Would like to order Fram CleanBreeze filter but they only go up to 2013 on their ordering site.
thanks for the how to!
My build: http://www.ramforumz.com/showthread.php?t=176640
Old 06-27-2014, 11:28 PM
Bunker Oil's Avatar
Bunker Oil Bunker Oil is offline
Vehicle: 2014 Dodge Ram
Trim Level: Longhorn
Color: white and gold
Bunker Oil is on a distinguished road
Default Just did my 2014 EcoDiesel
Couldn't believe these trucks didn't have a cabin air filter. Bought the kit off of E-Bay and installed it the other day. Took about 15minutes. Only thing I saw different, is a string that is tensioned to the lower glove box to remove and I unpluged a electrical conector while cutting to make sure I didn't knick any wires. It helped that I was left handed for cutting the slot out from the passeger door. Simple install and highly recomened.
Old 06-30-2014, 04:03 PM
wascobi wascobi is offline
Vehicle: 2010 Ram quad cab
Trim Level: sport
Rep:24
wascobi is on a distinguished road
Default hmm
just grabbed a fram cleanbreeze filter. $22 with tax at Canadian tire. my dealership does not believe in discounts. $24 for the cover, plus tax!
Old 07-02-2014, 07:36 PM
Budge Budge is offline
Vehicle: 2012 Ram 1500
Trim Level: Laramie 4X4
Budge is on a distinguished road
So I just finished this mod (thanks BTW), and I noticed that there is a white plastic "shutter" that looks like it moves up and down on top of the filter. When my truck is off, it's half way up. When my AC is on, the shutter goes all the way up. In this position, the fan is just drawing air from the area under the dash. So I tried using the recirculating button, and there was no change. Is my shutter just broken? Here's a pic.
Can't a fella have a maroon truck in Texas and NOT BE AN AGGIE? C'mon!
Add Cabin Air Filter to 4th Gen for less than $20 HoustonHemi Custom Dodge Ram Interior Modifications - Custom Audio / Video 217 02-05-2017 09:51 AM
Air Cabin Filter larryibc Heating & Cooling 3 08-29-2011 11:33 PM
Cabin air filter workhorse LD RAM - General Discussion 1 08-17-2011 12:59 PM
Cabin Air Filter Mod ciara Heating & Cooling 1 07-01-2011 12:55 AM
