Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Dodge Ram Decals
Old 08-28-2011, 02:32 PM
wolfman10's Avatar
wolfman10 wolfman10 is offline
Trim Level: SLT- Lonestar
Rep:188
wolfman10 has a spectacular aura aboutwolfman10 has a spectacular aura about
LOL....It wasn't a freebie. I went for the hose reel, but made the awful mistake of walking by the K&N display and did an 'impulse' purchase. These things are pretty expensive, so I was hiding it from the 'Boss'.
Understandable! Nonetheless, that's a good hiding spot!
-Cody
My Build: http://www.ramforumz.com/showthread.php?t=86853
Old 08-28-2011, 06:25 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
do you think it's farther back then the 3rd gen's.. i ran this way for awhile and it didn't seam to suffer in performance... back then when i was lightly modded I was still faster then most..
I believe it's back quite a bit further. The front of the air box is pretty much even with the front of the water pump.
The bottom is about level with the top of the head and about 4" from it.
As the OEM box has a decent sized intake pipe that is true cold air (ported and sealed to draw from the fender just behind the headlight), I think I would realize better gains from removing this accordion then from adding holes to the air box....although both is probably the best thing.
and talk about modding, we had a local gtg at sonics yesterday, talking to the guys, one of them just got a sharadon tranny he got from another Ram owner..one convo led to another and before you knew it we were driving the 1.5 hours back to my house and installed his tranny for him later that night...yea he was very happy with this mod..
Well that is bit larger 'impulse' decision than the one I made!
If I ever get a different DD and can keep this truck as my 'toy', I will likely go the Magnason route....which would lead to a trans issue...that would likely be best solved with something like a Sharadon.....Stage 3????
brad
Interested in one of my mods?
Old 08-28-2011, 07:10 PM
TerrysRam's Avatar
TerrysRam TerrysRam is offline
Vehicle: 2011 RAM 1500 4x4 SLT
Trim Level: Outdoorsman
Rep:16
TerrysRam is on a distinguished road
I'd be real interested in seeing if you could replace the corrugated tubing with something smoother. You'd almost have a CAI like the ones you'd buy. Hmmm.....
Rain-X Latitude wipers; Volant CAI - with ram air tubing; custom y pipe; Xlerator racing muffler; cats delete HemiFever custom Diablo tune; Line-X; Putco SilverLux LED headlamps; Putco Luminix LED fog lamps; Bilsteins 5100's all around, leveled up front; BFG AT KO 2's; KMC XD Battalion rims
Old 08-28-2011, 07:15 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
You could always cut out the bottom of the box and build and then seal your own intake tray with a tube running to the front bumper
2011 Big Horn 4x4 -SnowWhite-
Old 08-28-2011, 07:24 PM
brad12kx's Avatar
Rep:2581
That's the direction I'm thinking on. I how the flex section is there to account for the engine torque an it's affect on the distance from the TB to the air box, so a smooth piece would have to accommodate this requirement. I have to wonder is a manufactured slip join from plumbing pipe would work in this application. It would have to have a good seal and maintain it with a lot of movement though....Hmmm....
And it looks like there may be enough room to do just that. After I figure out how to get rid of the accordion, that will likely be the next item to mod. In both cases, I will do whatever I can to maintain the OEM look as much as possible.
brad
Old 08-28-2011, 10:00 PM
SS4Luck's Avatar
Rep:310
What about silicon pipe? I used it for an intake on my camaro before. You can get it in pretty much any size and bends, it can be kinda expensive though.
Im sure you could find square tin to use for a CAI scoop as well, could even make it easier to tie into a monting location?
Old 08-28-2011, 10:31 PM
brad12kx's Avatar
Rep:2581
Silicon pipe?? Where do I look for that? I'm intrigued.
I took another look at the air box tonight....but it got dark on me
I am going to look at the possibility of increasing the size of the front intake port (may be able to double it's effective size), and fabricating a new intake duct that utilizes both the existing factory upper fender location, as well as an additional location behind the front bumper. If I use the water float system out of a wet/dry vac in the lower pipe, I could keep it safe for those unexpected deep water events.
brad
K&N drop in filter mrcivic 2011 Dodge Ram Forum 20 08-01-2011 02:50 AM
CHEAP drop shocks! fowler2000 Suspension 1 05-09-2011 03:00 AM
How many coils to cut to get 2"-2.5" drop????? DodgeMyRam Suspension 1 03-02-2011 04:43 AM
Got the GroundForce 2/4 drop installed CdnoilRAM Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 19 06-18-2010 12:16 PM
Ball Hitch Drop Ken Towing 5 05-10-2010 08:51 AM
