Old 08-28-2011, 02:25 AM
Mudder's Avatar
Mudder Mudder is offline
Vehicle: 2012 Jeep Wrangler
Trim Level: Unlimited Sport
Rep:40
Mudder is on a distinguished road
Default Are side mirrors interchangeable?
My truck came with the just black heated mirrors and I prefer the looks of the chrome mirrors with the built in puddle lights etc. I wondered if they could simply be swapped out or if additional wiring would be required?
Old 08-28-2011, 02:37 AM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
The mirrors you're talking about are the ones on the laramies and laramie longhorns. I believe extra wiring may be needed because they tilt down when you back up
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 08-28-2011, 02:39 AM
Mudder's Avatar
Rep:40
Wow, had no idea they did that.
Old 08-28-2011, 02:57 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Can you just swap mirror covers maybe? Cuz i want to put white ones on my truck but it we have to swap over the whole mirror I may just pull mine off and have them painted
2011 Big Horn 4x4 -SnowWhite-
Old 08-28-2011, 03:01 AM
Mudder's Avatar
Rep:40
I would, but I don't think they made chrome mirrors that didn't have the puddle lamps, did they?
garner's Avatar
Rep:46
Do you have the mirrors with turn signals/entry lights?
Old 08-28-2011, 03:02 AM
garner's Avatar
Rep:46
Nope. No chrome mirrors without the puddle lamps
Old 08-28-2011, 01:09 PM
ramfan1500 ramfan1500 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: trx
Rep:63
ramfan1500 will become famous soon enough
I have a 2010 ram trx that came with black heated mirrors without puddle lamps in them. I swapped them out for a set of factory mirrors that had puddle lamps in them. The puddle lamps will not light up but the mirrors will darken now when a car is behind you so it was not a total waste of time. I took my truck to the dealer and had it flashed so that the lamps would work also but they tried and could not get them to come on because my truck did not come with them from the factory so the evic does not allow you to turn them on or make the mirrors tilt down when the truck is put in reverse, hope this helps
Old 08-28-2011, 01:14 PM
Porter_'s Avatar
Porter_ Porter_ is offline
Vehicle: 2011 Ram 1500 4x4
Rep:39
Porter_ is on a distinguished road
you'd think they would be able to flash the ECU so the puddle lamps can operate. unless there's an extra physical wiring harness, it should just be a matter of software control. it's a shame to read this because i would also consider swapping over to the nicer mirrors.
2011 Ram 1500 Big Horn 4x4 5.7L
1.5" TGC Leveling Kit, 305/55/20 Toyo Open Country A/T's
Old 08-28-2011, 05:01 PM
Mudder's Avatar
Rep:40
Great info, thanks. So basically, the swap would be purely cosmetic and the lights would be there just for show. Still, I like the chrome. Don't know if thatd bother me too much or not. So the mirrors still functioned just as your stock ones did, you just didnt get the benefits of the built in lights, correct? Tough call, hmm.
A/C low pressure valve leaking sonocativo Heating & Cooling 56 06-05-2013 04:40 PM
Side view mirrors bamamat Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 3 06-08-2011 01:18 PM
Chrome side view mirrors wanted harleysarge Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 1 06-08-2011 11:55 AM
Side Mirrors drag737 Electrical 8 09-10-2010 10:58 PM
Activating Side Heated Mirrors & Radio Traffic Warning Sign removal? RammD Dodge Ram General Discussion 2 07-31-2010 01:28 PM
