Old 04-14-2013, 10:32 AM
D33k D33k is offline
Vehicle: 2010 ram 1500
Rep:34
D33k is on a distinguished road
Originally Posted by Ryanb View Post
D33k what headlights are those? Also do you have different tail lights too?
They are the spyder projectors. And tails I'm just running the stockers tinted. But planning on running some led ones sooner or later.
Old 04-14-2013, 11:26 AM
Ryanb Ryanb is offline
Vehicle: 2014 Dodge Ram 1500
Rep:104
Ryanb will become famous soon enoughRyanb will become famous soon enough
Very nice love how it looks
SOLD! Extang Trifecta Tonneau Cover, Flowmaster Super 10s single in dual out, K&N 63 series cai, 20% tint, 6" RCX lift, Bilstiens at 1.4
Old 04-14-2013, 09:24 PM
nitrox28's Avatar
nitrox28 nitrox28 is offline
Vehicle: 2009 Ram 1500 SLT Big Horn
Trim Level: SLT Big Horn
Rep:14
nitrox28 is on a distinguished road
Originally Posted by Rayne View Post
Stock
Leveled
Lifted 4"
Can you run a leveling kit AND a lift kit at the same time?
2009 Ram 1500 crew cab. 4x4, Hemi, Big Horn. Spintech Super Pro Street muffler, Predator tuner, Volant CAI.
Old 04-14-2013, 09:31 PM
Rep:104
You can run Bilstein adjustable shocks in the front
Old 04-14-2013, 10:27 PM
Rep:34
Yes depending on the how the lift is setup in the front. For example I have the pro comp suspension that utilizes a strut spacer and preload coil spacers( similar to a leveling kit) if I put a leveling kit on I would remove my coil spacers (do not stack!!!!) also If I went with bilsteins I would remove the coil spacers and go with leveling shocks. Again do not stack.
Now you can add a leveling kit to your lift and many do. However many also have issues. You get added height however put your cv's at extreme angles, (if you do i would suggest kore cv's). I've talked extensively about adding more height on my kit with pro comp and they strongly suggest against adding anything on top of your lift.
It really depends on your differential drop, cv, how much you want to spend now/later. But yes is the answer.
Old 04-14-2013, 11:48 PM
2012ramsportellis's Avatar
2012ramsportellis 2012ramsportellis is offline
Vehicle: 2015 dodge powerwagon
Trim Level: power wagon
Color: blue streak pearl coat
Rep:94
2012ramsportellis will become famous soon enough
Day 1
rcx 2.5" front , 1.75 " rear leveling kit and 285-65-20 bfg's
Today 6" rcx lift , 1.4 bilstein's and 35-12.5-20 procomp xtreme tires on procomp series 7113 wheels with a 0 offset
Old 04-14-2013, 11:55 PM
Rep:104
Originally Posted by 2012ramsportellis View Post
Day 1
Looks great! Do you have any rake with your bilsteins set at 1.4?
Old 04-15-2013, 07:18 AM
chrispunkster's Avatar
chrispunkster chrispunkster is offline
Vehicle: 2001 dodge ram 1500
Trim Level: sport
chrispunkster is on a distinguished road
I have a 2001 with an 8" lift on it
the shocks look old and beat up pretty good
thinking of updating them but not sure what to get
dont want to go to expensive but do want stuff that is gonna blow out right way
any suggestions people
Old 04-15-2013, 02:55 PM
sporty11's Avatar
sporty11 sporty11 is offline
Vehicle: 11 Sport
Trim Level: sport
Rep:23
sporty11 is on a distinguished road
I figured there would be tons of info/reviews on my setup (cuz I've read it all! lol) so ill just post pics and specs! Enjoy!!
1.25" RCX Body Lift
2.1" Bilstein 5100's
Bilstein Rear shocks
2" Daystar Rear Spacer (Has 2" lowering springs)
Durun Terrain Grapplers in 35x12.5R20 on Stock rims with 1/4" spacer
Minor Rubbing on left tire on full lock. Rubbing is on plastic fender liner so not concerned at all...
Before: (36" Level all around)
After: (40" Front 41" Rear)
Also want to give a shout out to Andrew aka FastNugly for all the help and great prices!! Cheers!
Bilstein 5100's, 1.25" RCX BL, Toyo ATll 35x12.5, 20" Fuel Throttle 0 Offset, 10" L3's, 2500w Mono amp, AFE Stage 2 Intake, 180 deg, 14" Magnaflow, Stage 2 Jet Performance Module
Old 04-15-2013, 06:28 PM
JD454 JD454 is offline
Vehicle: 2002 dodge ram 1500
Color: Grey
Rep:14
JD454 is on a distinguished road
Parked at wallmart yesterday and found dirty dodge chilling so figured it would be a nice shot. Wish mine was that dirty right now
Looks to me like he has a level on it and 33's.
