Old 05-21-2014, 03:56 PM
NELLY83 NELLY83 is offline
Vehicle: 2013 ram 1500 express
Trim Level: express
NELLY83 is on a distinguished road
thanks Brandon, yes my truck is stock, I think the rims need to be 5" offset. those bilstein are expensive right? bullydog sells bilstein too?
Old 05-21-2014, 04:04 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
The rim offset (or backspacing as you referred to) can be a few different options depending on what you want. The 4 practical options you have are:
18x9 0 offset (5" backspacing)
18x9 -12 offset (4.5" backspacing)
18x10 -12 offset (5" backspacing)
18x10 -24 offset (4.5" backspacing)
Any wider than that and you're going to run into major rubbing problems with 37's. The 18x10 -24 offset would already be pushing it and require some trimming.
The Bilstein front adjustable struts are around $110 a piece I believe and yes Bully's Performance (different than Bully Dog) can get those as well. If you sent Eric an email and tell him I sent you he'll help you out right away and get you pricing on whatever you want.
Old 05-21-2014, 04:07 PM
Trim Level: express
yes my truck is stock,only thing I got is a flowmaster muffler, as far as poking out, I don't care about that,i just don't want them not to rub on anything. can bully build me a suspension kit with bliestien socks and everething?
Old 05-21-2014, 04:11 PM
Trim Level: express
sorry for the double post
Old 05-21-2014, 04:42 PM
Rep:2036
The 18x9 0 offset will give you the least chance of rubbing so if that's all you're concerned about those are the wheels to go with.
Yes, Bully's Performance can put together a full package for you including the lift, Bilsteins, wheels/tires, and anything else you may need to get the job done.
Old 05-21-2014, 04:46 PM
Trim Level: express
kool, thanks man, I sent a email, didn't get a reply yet
Old 05-22-2014, 12:07 PM
Is your truck completely stock right now or has it been leveled? 1" of rake isn't much for a stock truck.
I would recommend the 6" BDS kit with the 5" rear coils and the Fox 2.0 shocks. On the front you could either go for the Fox 2.0 coil overs or get a set of Bilsteins and set them at 1.4" to be level. That's typically the setup most guys will run. Contact the guys at Bully's Performance (sales@bullysperformance.com) and let them know that you're a forum member and what you want and they'll get you started and hook you up with the forum discount.
As far as running the 18's and 37's goes that's not an issue. You just need the correct rim size and offset to do it. How much poke do you want on your tires? That will factor in to what size and offset you want to run as well.
What he ^^^ said
Any questions, hit us up with an email
Old 05-22-2014, 05:38 PM
Rep:2036
100% stock the day I brought it home from the dealership
8" BDS long arm lift with Fox 2.0 shocks
Fox 2.0 dual steering stabilizer
37x13.5 Toyo MT's on stock wheels with 2" Motorsport Tech BORA spacers
If you want to see more pictures and read the full write up see posts 557-560 in my build thread linked in my signature.
Old 05-23-2014, 07:15 AM
Trim Level: express
nice!!
Old 05-23-2014, 10:54 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:358
^^^That is just plain badass.
333Half the beast
I used to be
