ZDOG
Old 08-28-2011, 04:11 PM
cyberpine cyberpine is offline
Vehicle: 2012 Ram Hemi regular cab
Rep:53
cyberpine will become famous soon enough
Default 18x9 wheel 33x12.5x8 tire on stock 2wd 4th gen?
Possible to fit 18x9 wheel 33x12.5x8 tire on stock 2wd 4th gen with no issues or rubbing?
Would imagine it's possible since stock 20 is roughly 33x12.5, but +19mm offset
I'm thinking maybe 18x9 -12mm offset with a 33x12.5x18 tire might fit without any issues. Can anybody confirm? Pics?
But WestKyCustoms is saying I need a 2 inch lift for this tire and rim.
http://www.westkycustoms.com/product...x18-Tires.html
If possible, what's a good agressive offset so some rubber sticks out but also to stay away from the rubbing inside anywhere?
Thanks.
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 08-29-2011, 03:13 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
Id think youd be alright with that tire. Im running a 34 1/2" tall tire thats 11 3/4" wide. Im using +18mm offset (19mm stock) and have about 1/4" clearance from the upper ball joint. I have a 2" level kit in front, but that really wont help the UBJ clearance only turning.
So to go +3/4" more w/ 30mm pushed out, Id say youd be OK even without a level kit. In theory you should be atleast. Some tires are different than others so no guarantees. Worse case is you have to buy/install a 2" level kit thatll cost you $80 but I think itll clear.
2015 Camaro 2SS/RS/1LE
Old 08-29-2011, 05:48 PM
Rep:53
3/4 inchs further out from stock is about +0mm offset if I'm at +18mm now. It would also be awsome to know if we can fit 325/50/20 on 20x9 -12mm offset rims .. I suspect so, but there is a fine line with going too far out and then rubbing on the wheel well on rough rides. Really not looking to lift or level if possible. But if changing rims, I probably would step down to 18x9 and try to fit 305/60/18.. which I hear I can do on 18x9 +0mm offset rims.
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 96 01-16-2016 08:50 AM
New Lift, tire, wheel Combo? okieram25 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 11 06-29-2011 09:12 PM
largest tire on stock wheel billy ho Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 10-11-2010 01:06 AM
Wheel / Tire Upgrade RAMitDOWN 2009 Dodge Ram Forum 5 07-28-2009 01:28 PM
Wheel & Tire Questions Lil Azn Dave Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 07-01-2009 03:41 PM
