Diamo 17k wheels with Kumho Road Venture MT - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-28-2011, 06:53 PM
unrealtrip's Avatar
unrealtrip unrealtrip is offline
Vehicle: 2008 Ram Big Horn 4x4
Rep:27
unrealtrip is on a distinguished road
Default Diamo 17k wheels with Kumho Road Venture MT
About to buy this tire/wheel set, seems like a pretty good deal.
Thought I'd check to see what y'all thought before I hit send. You know, just in case someone says "um dude, you know -12mm and 4.5" backspace won't work right" lol
http://www.westkycustoms.com/product...017-Tires.html
Complete Wheel and Tire package! (4) Wheels, (4) Tires, mounted/balanced, center caps, Dual Seal Chrome Valve Stems, Lugs/Locks...Ready to Bolt on!
Wheel Specs:
Diamo 17K 17x10 Black
-12mm Offset (4.5" backspacing)
1 Year Finish Warranty!
Lifetime Structural Warranty!
Tire Specs: For H2s with stock suspension and 4WD Trucks/SUVs with lifted suspension
Diameter: 34.6"
Width: 12.7"
Treadwear: NA
Traction: NA
Temperature: NA
Load Range: D 8 Ply
I've got a shotgun a rifle and a four wheel drive...
Old 08-29-2011, 02:34 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
just so you know -12 and 4.5 are the same measurement.
Are you lifted? -12mm will stick out from stock. Stock is usually in the +15mm range i believe, but i know negative will stick out
2011 Big Horn 4x4 -SnowWhite-
Old 08-29-2011, 06:17 AM
unrealtrip's Avatar
Rep:27
Actually the -12mm is the offset and the 4.5" is the backspace. I know they will stick out some, just not sure how much, hard to visualize. But yeah, I'm also throwing a 2" lift on at the same time, will try to get lots of pictures.
Old 08-29-2011, 03:14 PM
unrealtrip's Avatar
Rep:27
Ended up going with those Kumho tires, but XD Cranks instead.
Old 08-29-2011, 07:10 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
thoes will look good but wheres the installed pics?
Old 08-29-2011, 07:57 PM
unrealtrip's Avatar
Rep:27
Just ordered them today, I'll have pix once I get them and my Daystar installed when they arrive.
315/70/17 or 33/12.50/18 kumho road venture MT KL71 motodefaz Dodge Ram Wheels And Tires 9 10-14-2014 03:51 PM
Chrome Clad OEM wheels harleysarge Dodge Ram Wheels And Tires 8 11-17-2013 09:13 PM
Calgary road rules...thought it was funny CdnoilRAM Jokes/Humor 29 04-27-2012 01:15 PM
Which wheels? jcasey10 Dodge Ram Wheels And Tires 9 09-28-2010 09:28 PM
