Old 08-29-2011, 10:16 AM
cyberpine cyberpine is offline
Vehicle: 2010 Dodge Ram Quad Cab Hemi
Rep:53
cyberpine will become famous soon enough
Default 18x9 offset sweet spot for 305/60/18?
sorry for the duplicate posts.. posted in wrong section and got no response.
The people are West KY Customs are saying I can fit a 305/60/18 on my stock 4th gen 2wd on 18x9 rims with +0mm offset, but that the that tire will rub on a +12mm offset or -12mm offset. But I'm thnking there info was collected on 3rd gens and not 4th gens.
Anybody got info to support or contradict that?
Thanks.
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 08-29-2011, 01:15 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Those are shorter than my stock 20" wheels/tires. I think they have their info wrong, the 0 offset would sit out a little bit from factory and the +12 would sit nearly stock looking inside the wheel well
2011 Big Horn 4x4 -SnowWhite-
Old 08-29-2011, 02:26 PM
Rep:53
Thinking shorter rims rub in different places, likely cause where the tire bubbles much lower.. possibly the A-arm. So what they are saying is (I think) -12mm is too far out and +12mm is too far in. In all 1 inch differnce between the two extremes. But somehow +0mm is acceptable?
Personally I do think on 305/60/18 that +12mm (on 18x9) is too far in, but suspect -12mm might be fine.
Related, On 20s (not 18s) A while back a Wheel place told me I could run 305/55/20s on 20x9 if I stayed between 0mm and -10mm offset .. any further in or out and i'd be looking at problems. Which makes sense considering guys with 305/55/20s on stock 20s (+18mm), have get a 1/4 spacers to not rub. The offset on our stock 20s and obstructions in the 2wd do really limit choices.
Old 08-30-2011, 03:49 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
No issues with my rear 18x9 w/ +18mm offset
I do rub at full wheel lock with my front 17x9 w/ +18mm offset.
Front tires are 275/55/17 though.
Old 08-30-2011, 06:09 PM
Rep:53
you have two different size rims? 275/55/17 is a 29 inch high tire.
Most of our problems is that damn +18mm offset. So many more tire options if the rims had more negative offset.
Still waiting for somebody to do that 18x9 -12mm 305/60/18 combo and share expeirence before I do a $2000 experiment.
Old 08-31-2011, 06:05 PM
Color: Satin Orange
Rep:597
yes i have a staggered setup. 305/45/18 Nitto Nt5555r Drag Radials in the rear.
Old 09-02-2011, 08:41 PM
Rep:53
Got pics of your truck anywhere online?
Thanks.
Old 04-19-2013, 05:31 PM
bmx2day bmx2day is offline
Vehicle: 11 1500 Sport
bmx2day is on a distinguished road
I just ordered a set of 18x9 0 offset xd wheels and 325/60/r18 Toyos today and should be on next week, I will be sure or post pictures and let you know. I am worried a little a may need a spacer but we will see.
18x9 Black XD Rockstars and 305/60/18s on Stock 2wd 4th gen? cyberpine Suspension 1 08-30-2011 08:24 AM
mds sweet spot - doubling mpg? cyberpine Dodge Ram General Discussion 1 05-04-2011 08:29 PM
Vintage negative offset type rims cyberpine 2010 Dodge Ram Forum 2 04-06-2011 11:36 AM
17" wheels off for new dodge. DODGE4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 11-25-2009 03:28 AM
