Old 08-30-2011, 05:44 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
^good point definitely have an advantage with computer controlled vehicles. I am used to carbed. I ran a 272 adv (I think it was around 215intake/220exhaust @ .05) and about .49 intake/.5 exhaust lift cam in my carbed ford and it wouldn't hold an idle under 1,000 rpm. If you can tune it to a good idle then go as aggressive as you'd like, just remember usually the more aggressive = higher rpm powerband and less mpg. You don't want a cam that doesn't have power until 3,000rpm when most of your driving is at 1,000-3,000rpm. Those cams you posted above should be good for power around 1,500-2,000 rpm and up I'd think.
That is exactly my thinking. I know that Hemifever could dial in any of these cams and make it idle. I just don't want to go with a cam that is going to be so big that I lose bottom end and gain a huge top end that I won't be able to get full use out of. Need to keep as much bottom end as possible to get my heavy truck going.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 08-30-2011, 06:25 PM
TheSatinPumpkin's Avatar
Color: Satin Orange
Rep:605
You think Sean can squeeze more out of the Sidewinder?
Old 08-30-2011, 06:29 PM
ORT's Avatar
ORT ORT is offline
Rep:184
I doubt it. He has the tune pretty much dialed in. She idles real smooth, a/f and fuel trims are all dead on. Seems like he is getting all there is to get out of this cam.
Old 08-30-2011, 06:57 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I think the one kay9 suggested would suite your needs, the hellfire I think it was? Or that other one, I think it was the sparrow.....
Sean
Old 08-30-2011, 07:19 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
http://www.streetfire.net/video/hemi...ads_145160.htm
Old 08-30-2011, 07:37 PM
Color: Satin Orange
Rep:605
Were you able to get some track numbers or is it mostly just for the street?
I remember a post where you had pretty low 5.xx 0-60's logs. That's moving period on the street.
In regards to the Spartan Max.
Bgorng on DT has a close trim like you (4x4 qc) and ran 13.8 @ 98 and 12.49 at 107 w/ 100 shot.
Granted he also had BV heads but he also had 3.55's and stock stall. He advised the temps were 90 degs with 40% humidity.
Got a feeling there is going to be quite a few PB's this year when it cools down.
Your right it was the Hellfire.
Old 08-30-2011, 07:43 PM
Color: Satin Orange
Rep:605
That's sweet.
400rwhphemi brought my Comp 273 for his Magnum.
Originally Posted by 916Timmy View Post
Old 08-30-2011, 08:31 PM
ORT's Avatar
ORT ORT is offline
Rep:184
My truck is strictly for the street with the hopes of getting to the track every once in a blue moon just to see how she compares to other trucks. I have logged as low as 5.09 for 0-60 which is a solid time. But since then I feel like the truck has plateaud and I am looking for something to get her faster without having to drop big cash on heads or some form of power adder.
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
Front CAM Finally Installed. RansRAM Custom Dodge Ram Interior Modifications - Custom Audio / Video 38 09-27-2011 08:55 PM
whos running a bigger cam? dodgeman2289 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 8 06-09-2011 03:02 AM
Cam Question dodgeguy123 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 4 01-19-2011 02:05 AM
Thinking about the H/O Cam from AIRRAM.com Silver05Ram Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 10 07-20-2010 12:51 PM
