Old 08-31-2011, 04:14 AM
Sean2010 Sean2010 is offline
Trim Level: Sport Crew Cab
Color: Black on Black
Sean2010 is on a distinguished road
Default 4th Gen and Cams?????
I see a few people have aftermarket cams in there signatures but I am curious because no one list the 4th gen rams for these cams can someone enlighten me as to what it takes and which cams you guy are using that work in our trucks??
thanks
Old 08-31-2011, 09:07 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Arrington makes cams for 4th gens
http://www.shophemi.com/c-327-hemi-p...nce-parts.aspx
2011 Big Horn 4x4 -SnowWhite-
Old 08-31-2011, 04:21 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Inertia Motorsports
http://inertiamotorsports.com/camshafts.html
Old 09-01-2011, 11:12 PM
Ram Pants's Avatar
Ram Pants Ram Pants is offline
Ram Pants is on a distinguished road
I have read that some are also running Comp cams XFI 260H series cam. Its a rather mild cam that other hemi's have been running that seems to work out ok with MDS. I'm curiuos if anyone has decided to take on the cam swap in their driveway. I would like to tackle it myself if possible but would like to know what are the real difficult points from access and tools.
Old 09-01-2011, 11:18 PM
SS4Luck's Avatar
Rep:310
Im sure if you pull the grill and radiator itll leave the engine's front dress right out in the open and just start pulling the front of the engine down from there?
Old 09-01-2011, 11:35 PM
thanks guys.
I have noticed none of them have a large lump and I have looked at a few video with similar cams in similar cars/trucks and they don't seem to really sound like thy have a cam. performance aside I wish it would sound better. any thoughts??
Old 09-01-2011, 11:38 PM
SS4Luck's Avatar
Rep:310
I would call either Arrington or Inertia. They will be able to help you better
Old 09-01-2011, 11:57 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Originally Posted by Sean2010 View Post
thanks guys.
Welcome to the wonderful world of roller cams.
Most of the stock roller cams have a better performance spec than many of the most radical cams of days gone by. We no longer have to put up with the terrible idle issues, and low RPM problems that were prevalent in the 70's and 80's.....and for the most part...90's.
The beauty of the beast is it's ability to ramp from fully closed to fully open in a fraction of the time, so we no longer have to deal with the massive overlap that caused the poor idle and low RPM performance......that many of us grew to love the sound of.....
Can you get a cam that will bring back those memories....probably...but you will likely have to contend with performance issues, as the cam will have to be custom ground to a less than optimal spec to create that lump and lope.
I'm sure the major cam manufactures would accommodate your request, but will likely ask you for the grind spec, and will accept no responsibility for it's performance or it's drivability.
brad
Interested in one of my mods?
Old 09-02-2011, 08:38 AM
Color: Satin Orange
Rep:627
260 wont work with yours.
Old 09-02-2011, 08:43 AM
Color: Satin Orange
Rep:627
What years are you looking at? Dont think there are many cam videos to look at for your generation.
thanks guys.
