jus wonderin here...programmers,etc ? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 08-31-2011, 10:02 AM
cj5orion's Avatar
cj5orion cj5orion is offline
Vehicle: '98 ram 1500,mag,4-whl,lifted
Color: green
cj5orion is on a distinguished road
Default jus wonderin here...programmers,etc ?
Once ya buy one,use it to "program" your truck....
then what ?...it sits ona shelf in the garage ?
jus wonderin
'98 ram 1500,skyjacker lift,BFG Mudders,Magnaflow exhaust
aaaaaand 1 choc lab----bird dog !
Old 08-31-2011, 10:17 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Yep! I leave mine in my truck in case I need to use lower grade gas and have to change the tune. But it is a set and forget operation!
Old 08-31-2011, 10:32 AM
CollateralDamage's Avatar
CollateralDamage CollateralDamage is offline
Vehicle: 2010 Ram 1500 SLT
Trim Level: SLT Plus
Rep:50
CollateralDamage will become famous soon enough
Unless you buy a Trinity then you can use it for extra gauges, dataloging etc...
http://diablosport.com/index.php?mod...isplay&pid=151
CollateralDamage
2010 Ram 1500 SLT Plus Crew Cab "Mineral Grey"
Old 08-31-2011, 11:56 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
^ I leave mine under my seat because of the same reason as Timmy, if I randomly need to tow/haul, or just change fuel grade I'll need to re tune. Also they say if you ever have an issue it will be when you are on a road trip and your tuner is in the garage....so it's beneficial to have it with you just in case. I also use it for data logging/gauges sometimes.
Sean
Old 08-31-2011, 02:39 PM
He can't use the Trinity on a 1998 Ram.
So yeah, any tuner you get will sit on the shelf after you load the program to the truck. Which is OK, really, since the key piece of the tuner is on your truck's pcm.
