Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-31-2011, 12:48 PM
Leviathan79 Leviathan79 is offline
Vehicle: 1999 Dodge Ram
Trim Level: 1500 SLT
Leviathan79 is on a distinguished road
Default Water pump pulley?
So my 99 Ram 1500 (318) is leaking coolant from the area of the water pump like a gunshot victim. I went down to oreillys to pick up a new one, and apparently there are 2 different kinds: one for a bolt-on pulley and one for a pull-off pulley. How can i determine which one i have without taking off the fan? Not having a lot of free time, i was just going to save some $$ by buying the pump and just taking it in to have it replaced, but if i have to tear everything apart just to find out, i might as well just do it. Can anyone tell me an easy way to find out which kind of pump i have?
Old 09-02-2011, 08:50 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Ok well the first thing you want to do is make sure it's not the bypass hose that is leaking, if the bypass hose is leaking it is very easy to mis-diagnose a bad water pump as this has happened to me but I was smart enough to stick my finger under the accessory bracket and feel the underside of the bypass hose and to my luck their was a cut in it. Small 10 dollar hose or make it your self 50 cents. Anyways you are going to have the remove the fan and drive anyways, just a tip of advice to save you the headache lol don't try to remove the fan with the serp belt on because the pulley will spin in the belt, the easy thing to do is to buy a water pump pulley tool, it looks like a giant "U" and the end and on each end is 2 metal pins that stick out, these pins pop into the pulley allowing you to hold the pulley in place while you go in with a adj crescent wrench and remove the bolt. Elsewise it's quite hard to move the fan drive from the pulley.
Broken water pump impeller jintx 4.7L PowerTech V8 Specific Topics 10 07-08-2013 02:09 PM
Water Pump & Timing-Chain Cover Gasket Replaced! dewzram 5.9L V8 Specific Topics 14 11-22-2011 09:58 PM
Replacing Water Pump (Question) How do I remove fan from waterpump pulley MMMMDude 5.9L V8 Specific Topics 6 01-31-2011 02:12 PM
replacing water pump Scorn440 5.9L V8 Specific Topics 20 10-02-2010 04:57 PM
28-ounce water pump hemiv8dodgeram1500 Jokes/Humor 13 01-31-2010 04:49 PM
