Old 08-13-2012, 04:22 PM
TonyD87's Avatar
TonyD87 TonyD87 is offline
Vehicle: 2011 Ram 1500
Color: Gray
TonyD87 is on a distinguished road
I would go with the ground force 2 and 3 drop. I have put 2k miles on mine and I haven't had any problems. I did the install myself and it took a good part of the day but it was well worth it. I also installed a set of helwig sway bars for the front and the rear and it really helped out the ride.
Old 08-13-2012, 04:24 PM
InDeepWaterBlue's Avatar
Rep:611
Honestly I have a BellTech Kit and I don't know if they've resolved the issues others have had with them. Personally I had no issues with them but I would consider the McGaughy's with the drop spindle as that's a really good kit as well.
Old 08-13-2012, 04:30 PM
Rep:611
Might want to annotate that the express also doesn't come equipped with sway bars where the other models do, not trying to step on your toes bud I had factory sway bars with the shorter end links and it works great. I've personally put over 10k miles on my kit including a recent trip to an old short circuit Nascar track out in Byron GA, nosing into banked corners hard and the body roll was minimal, you should see the look on a LX drivers face when you're on the inside passing
Old 08-13-2012, 05:47 PM
2011lonestarhemi 2011lonestarhemi is offline
Vehicle: 2011 Dodge Ram LoneStar Quad
Trim Level: LoneStar-SLT
2011lonestarhemi is on a distinguished road
Truck pulling to the right, got the alignment checked AGAIN, they say it is aligned, I am considering pulling off the belltech feels unsafe at speed with wobbly rear end, and malaligned front end, I have never wrecked the truck, only 16,000 miles on it. Pretty much BellTech has been a headache for me. Considered a spohn adjustable panhard bar (to fix the wobbly rear end), just so I don't have to take off the lowering kit.
Old 08-20-2012, 10:21 PM
2011redrt 2011redrt is offline
Vehicle: 2014 RT
Trim Level: RT
Rep:25
2011redrt is on a distinguished road
You might have something else going on. Maybe a bent wheel or ????? The lowered stance might be high lighting the issue. I just can't see the rear offset being the issue when others are driving under the same set-up with no issues. I had a 2011 RT with the bell tech kit and had no issues....
Old 08-20-2012, 11:21 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Without lowering the panhard bar bracket to keep the bar level to the ground you will always have that side to side floating feeling at speed over bumps. It's loading the rear-end to one side. Panhard bars have to be level to function properly. The adjustable bar will help to center your axle....it won't help the main issue though.
Old 11-23-2012, 10:30 AM
mikek43 mikek43 is offline
Vehicle: 2011 Dodge ram
Trim Level: RT
Color: RED
mikek43 is on a distinguished road
Talking help
Well I know this maybe a little LATER, but I just picked up a couple months ago a 2011 R/T and really want to lower her.
I was set to go the BellTec with shocks, till I discovered NO panhard rod relocator and your issues. They then told me one was in development. So to wait a few months. well beena few months and NOW they tell me NO relocator yet or if ever?? So it seems like you are having issues with your kits by BellTec?? Can you tell me more or if resolveed. I want the SAME ride quality I have now but a lower ride height. My wife and I are not tall people,plus lowered some looks so much better. thanks I appreciate the help.. Mike
Old 11-23-2012, 03:21 PM
Vehicle: 2014 RT
Trim Level: RT
Rep:25
I do not know what is causing all the problems this member is posting about but it is not 100% related to BT kit. It can't be. Too many people are running these kits with minimal issues. I agree that until the panhard bar is relocated there will be a slight side to side motion over large bumps. I did not want to post until I had some miles on my new 2012 crew. So now I have 2 trucks with BT kits to compare. The first was a 2011 RT and now a 2012 Crew both with the spring shock combo. We can argue all day lone on what kit is the best but the bottom line is price and quality. The spindle kit set the front wheels out and for me I don't want that. One of the other kits we did measurement comparisons and BT was a full inch lower making it a true 2-4 drop. As it stands today I have made on trip of over 1200 miles that was through mountains and some flats, smooth roads and rough roads. The BT performed very well. This trip was also taken last year in my RT so I have a complete comparison. In addition I took a 2000 mile trip earlier this fall before it was lowered. I asked my wife her opinion and she said it road about the same. Just thought on the rough roads it was a little harsher but very comfortable. No dangerous issues or the feel of out of control behavior. Just my 2 cents.
Old 11-23-2012, 04:59 PM
Rep:611
Personally I have the BT kit with the Street Performance shocks and love it, yes there is a slight side to side motion on bumps, but I bought a Spohn Performance Adjustable Panhard bar and will be using that to fix the issue. Honestly I've had it for quite a while just haven't had the time to install it lol But I've taken the truck all the way from Florida to Tennessee, than on another trip from Florida to Pennsylvania and had no problems. The truck rides smooth and can take a corner much better than before. Also took it to Perry GA where some of us got access to a Nascar track that has been shut down for over 20 years. I ran it hard, nose dived into corners and ran high bank turns to what I felt was dangerous and the truck was planted. The only time I can feel that weird motion is when I'm on some of the bridges here have little whoop sections in them.
Old 03-07-2013, 04:05 AM
what size tires are y'all running with the BT 2/4 drop?
2011 Ram 1500 advice before buying airborne89 2011 Dodge Ram Forum 32 06-25-2011 01:34 PM
Drop the rear on 2011? stangallmotor 2011 Dodge Ram Forum 6 03-28-2011 08:31 AM
Intoduction and advice on 2011 Ram R/T Single cab 1stRAMowner Newbie Checkin! 13 01-27-2011 09:28 AM
