Place your Ad Here!
Old 09-01-2011, 06:11 AM
Stonednloaded Stonednloaded is offline
Rep:14
Stonednloaded is on a distinguished road
Default PIAA lights and switch
got a bull bar for my truck and i picked out a set of PIAA lights to go on it their the PIAA 520 Series just wanted to know if their the best series lights to get I want as white or bright as i can get not yellow also is there a good switch that looks nice that I can buy for the hook up ....I like to have a button that looks like all the ones on my dash now like tow haul and that....and just put it in one of the blank spots on the dash next to one of these if possible ...or any nice switch you know of let me know... thanks
Old 09-05-2011, 01:49 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I don't have an answer so, it's time to .................... this back to the top!
I see you've been here a while but haven't dropped by the Newbie Checkin yet. So how about using the link in my SIG to jump over and introduce yourself? Hope to see you around!
Old 09-05-2011, 08:41 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
I don't know about the lights that you chose being "the best", but they are certainly good quality lights. I, myself have always been partial to the KC Hi-Lighters/ Day-Lighters but that is just me. Pretty much any good quality light that you're happy with is probably the best for you. Mostly it comes down to personal opinions and choice.
As far as the switch goes... You should be able to find one that fits where you want it, and does what you want it to do. I would start off at my local speed shops and auto parts stores. If I didn't find anything there I'd move on to electronic supply/ parts stores such as radio shack or even a specialty shop. If you can't find it locally then I'm sure with enough searching you can find one online.
When you start your search make sure the switch is rated for the proper amperage and voltage. I'm not sure what the physical size of the "dummy switches" are but measuring them might be a good start there.
****edit*** I just thought that you might be able to check with your dealer's parts department to order a switch for the center panel to replace the dummy. It should work provided the amperage rating isn't exceeded.
good luck and be sure to post pics when you get everything installed
Exco
Bill
Old 09-05-2011, 09:14 AM
Bordin's Avatar
Bordin Bordin is offline
Rep:516
Hey man,
Have a set of PIAA lights myself and I hated the stock stick on switch. I didn't bother going to the dealer to get the AUX switch bank.
I just installed some green illuminated switches myself. Its not that complicated.
Here ya go! Send a pm if your interested
Old 09-14-2011, 08:51 AM
jgatlin jgatlin is offline
Vehicle: 2011 Dodge Ram
Rep:18
jgatlin is on a distinguished road
Great switch placement, what kind of a job was it to get the wiring and holes drilled for those switches?
Old 09-14-2011, 02:30 PM
The PIAA units are good, for a halogen, but will still look a bit weak white or yellow to you, especially if you already have HID's.
Hella has some nice lights you might be interested in:
LED units: http://www.myhellalights.com/index.p...ary-lamps/led/
Xenon units: http://www.myhellalights.com/index.p...s/xenon-lamps/
And the Xenon units are HID upgradeable:
http://www.myhellalights.com/index.p...enon-capsules/
My plan is to keep my Hella 500 Black Magic set and add the Rallye 4000 Xenon set with an HID upgrade.
http://www.myhellalights.com/index.p...ye-4000-xenon/
Old 09-14-2011, 03:00 PM
Rep:2910
If you have a 4 wheel drive, like in the image above, that is a handy place to put the switches
if you only have 2 wheel drive, you could do what i did for my auxiliary rotating orange lights & 2nd fuel tank
Old 09-14-2011, 03:22 PM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
Does anyone know if there are aux switches available that fit the blanks where the Tow/Haul, ESP etc. switches are? I know there is an aux panel that fits the Ram panel below it but that might be more than needed and apparently almost $400 for the whole set-up.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 18 06-09-2017 09:33 AM
No backup lights DadzDodge Electrical 10 11-26-2013 01:31 AM
exhaust, fender lights, light switch 95ramstang02 Body & Interior 3 01-21-2011 11:44 PM
horn separate switch dead short..help! String13 Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 12-31-2010 10:20 AM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
