Old 09-01-2011, 06:02 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Default Quick question on the L04 Tie Rod Recall...
Guys -
I have an appt for my dealer to do my outer tie rod ends per the L04 recall.
Question - if outer tie rod ends are being replaced, shouldn't the front end be lined up as well?
Rich
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 09-01-2011, 06:55 PM
Dustinmc15 Dustinmc15 is offline
Rep:73
Dustinmc15 will become famous soon enough
Yes, it should be aligned and the dealer should do it for free under the recall.
Old 09-01-2011, 10:10 PM
Turbovsix's Avatar
Rep:83
"Should" is the key word. I went through a big production because they were initially against replacing the tie rod ends - said they would "check" them first as per the procedure with recalls, and I said the recall specifically states to REPLACE THEM.
I think I'm heading off to a different dealer because they'll definitely give me an issue with the alignment. Wish Chrysler would have stated that an alignment is required in the recall just to avoid dealer issues.
Rich -
Old 09-02-2011, 02:22 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
Dealer said the same thing to me when I called for appointment, they will check them first and then determine if they need to order the parts. Off to fight with them...again...
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 09-02-2011, 02:57 PM
10ramisport's Avatar
10ramisport 10ramisport is offline
Vehicle: 2010 Dodge Ram 1500 CC
Trim Level: Sport 4x4
Rep:73
10ramisport will become famous soon enough
Hey guys, I just had this done on Tuesday and they did an alignment as well. When I called for an appt. the service advisor said nothing about checking the tie rods first. I asked if they were doing an alignment afterwards and he said yes. Pretty much, if you mess with the tie rods it needs an alignment...Period. Brought the truck there, they R2 'em and did an alignment. Unfortunately, my steering wheel is slightly off and they will be realigning it no charge
BTW..Turbovsix I love the name I have 2 87 GNs as well...a hardtop show car and a mean street/strip beast. Nice to see a forum member with one.
Old 09-02-2011, 06:09 PM
Turbovsix's Avatar
Rep:83
Yeah, I called another dealer I've dealt with in the past and they didn't have any issue in replacing the tie rod ends, ESPECIALLY SINCE THAT'S WHAT THE MOTHERED RECALL SAYS. And they confirmed that they "reset the toe", but they don't do a full four wheel alignment. Resetting the toe sounds about right to me I guess.
I will be writing a letter to my other dealer and ending that relationship. Just one event in a string of many bad dealings. Effing AHOLES.
Rich -
Old 09-03-2011, 01:56 PM
Ray's Avatar
Ray Ray is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Rep:45
Ray is on a distinguished road
I just got my notice in the mail today to have mine replaced(recall L04) I havent experinced any clunking noise like the notice said migh be caused by the outer tie rods,but I have noticed when I hit a minor bump in the road my truck will react like I just hit a deer and bounce to either the left or right. So my question is will having the outer Tie rods replaced correct this problem and tighten up the ride a little bit.
Mods:Mopar fiber glass Tonneau cover,Nerf Bars,Bully Hitch bar,husky mud guards,stubby antenna,Edge guards,weather mats,20%tint all around+windsheild,lisence plate covers,Upgrage to REN w/back up cam,Magnaflow 18, putco bulbs,LED interior/plate bulbs,viper smartstart
Old 09-03-2011, 05:08 PM
mtbiker033's Avatar
mtbiker033 mtbiker033 is offline
Rep:25
mtbiker033 is on a distinguished road
I had mine done today and alignment is part of the procedure.
2010 Dodge Ram 1500 Quad Cab // K&N Drop in // Tint (20% rear / 35% front)
Old 09-04-2011, 09:21 PM
TimsHemi's Avatar
TimsHemi TimsHemi is offline
Rep:20
TimsHemi is on a distinguished road
I had mine done after an inspection of my front end.... After the lif tkit was installed.. At the time I had no idea there was a recall.. I was expecting a hard time because of the lift kit, but they went and had it aligned as well no issues...
Old 09-05-2011, 12:22 PM
BlackBullet's Avatar
BlackBullet BlackBullet is offline
Vehicle: 2010 Ram Hemi TRX4
Trim Level: TRX4
Color: Brilliant Black Met
Rep:39
BlackBullet is on a distinguished road
hey, outta curiosity, which dealer as i bought mine in jersey, thanks.
Leveling kit, DSP tuner, 14" MAGNAFLOW with side exit, heavy duty DODGE slush mats, DODGE bed mat,BILLET TECH catch can, STAINLESS steel door sills, K@N drop in filter, level ride airbag suspension....
Quick question on wire color SS4Luck Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 08-29-2011 10:04 PM
Quick Trans question... Turbovsix 2010 Dodge Ram Forum 4 08-03-2010 04:38 PM
quick question matt miller Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 08-01-2010 11:39 PM
Quick CAI question wester399 Dodge Ram General Discussion 19 01-10-2010 03:09 PM
Quick question guys and gals brandonterrill Dodge Ram General Discussion 14 01-05-2010 09:41 PM
