Old 09-01-2011, 06:22 PM
dlusery dlusery is offline
Vehicle: 2007 Ram 1500 4x4
Trim Level: Thunder Road
dlusery is on a distinguished road
Default Lots of coolant leaks!!!!!!!
My 2007 Hemi has had an intermittent coolant leak for several months. It started as a small puddle near the left rear of the engine, but after a few weeks it became more intense and expanded to include the front of the engine too. The most obvious leak was coming from the thermostat gasket (I've replaced it twice in the last 4 months). After that repair, I saw coolant on my lower-rear exhaust manifold bolts (both sides). I removed them, cleaned the threads and put hi-temp thread sealer on them. That fixed most of my problems. Now it looks like the water pump gasket is leaking. Un-freakin-believable. The truck has 48k miles on it and uses more coolant than fuel. I'll never buy another one!
Old 09-02-2011, 08:43 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
You are the best example for people who think or in your case thought that the newer rams are better then the older ones. Ha they just keep getting worse... Anyways not knowing this but be sure you torque everything to spec including that thermostat housing.
Old 09-04-2011, 03:21 PM
BadHazard's Avatar
BadHazard BadHazard is offline
Vehicle: 2006 QCSB, 1500
Color: Inferno Red
BadHazard is on a distinguished road
you know every make and model has problems. My old ford 150 had its fair share of 4x4 problems. Sounds like your fixes shouldnt have cost that much. And it probably all happended at once.
06 QCSB, 1500, Laramie, 4x4 50k. 18" Rockstars, K&N Drop in Filter, Muffler Delete, SuperChip
Old 09-04-2011, 03:55 PM
Rep:2657
I have worked on many makes of vehicles
The Blue Oval is the worst for water leaks, i usually just replaced factory freeze plugs with BRASS freeze plugs,
With a couple Fords i had to get a machine shop to thread the freeze plug holes & then put in a threaded plug
Every brand has issues, some are a real pain
ramvan2500's Avatar
Rep:128
Well things like coolant leaks and failed pumps are inevitable. But you're right all vehicles have a defect one way or another. But for the most parts I can admit the older rams I think are much better then the newer rams. But a cars a car...
Old 09-08-2011, 05:58 PM
BadHazard's Avatar
Color: Inferno Red
i hope mine lasts a while lol. my 04.5 cummins was a money pit :\
Problem: Coolant smell from engine but no smoke or water in oil (see pics) elektromaniak Heating & Cooling 7 06-04-2011 07:50 AM
Coolant dissappearing sritter Heating & Cooling 13 12-29-2010 04:09 PM
Coolant leaking from AC Compressor...WTF? 96Ram1500 Heating & Cooling 8 09-26-2010 10:08 PM
Low Coolant and Overheat but no leaks? yankeefan4ever 4.7L PowerTech V8 Specific Topics 14 01-10-2010 02:15 AM
Coolant leak. Bad rad? bigdaddyII 4.7L PowerTech V8 Specific Topics 17 12-16-2009 07:26 PM
