545RFE trans service help/advice/tips!? - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 09-06-2011, 07:43 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I am confused I thought the 4.7L had the same trans and would use the same filter(s)? Since you have a 4.7L armyofone and you've done this can you help?
Sean
Old 09-06-2011, 07:48 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
when I was looking for filters Wix listed a 4x4 kit and a 2wd kit.
Old 09-06-2011, 07:54 PM
snrusnak's Avatar
Rep:1388
so chvyklr, since yours is 2wd did you only have one filter? Or did you still have 2 filters? According to the autozone database the 4.7L 2wd had one filter, and the hemi 2wd had both...agh stuff like this is so frustrating lol.
Sean
Old 09-06-2011, 07:57 PM
CHVYKLR's Avatar
Rep:252
sorry, shoulda gave you more info. the Wix kit I ordered off Amazon came with both (spin on & flat) filters in one box. they listed 2 different P/Ns (4x4 & 2wd). I think the only difference is in the flat filter.
Old 09-06-2011, 08:01 PM
snrusnak's Avatar
Rep:1388
Ok thanks. I wonder if autozone just lists the other filter separate for some reason (assuming I do have both). Do you guys know the proper names of both filters so I can ask them tomorrow? I may call dodge as well just to see if there are differences...
Sean
Old 09-06-2011, 08:13 PM
CHVYKLR's Avatar
Rep:252
sean - you are 2wd right?
if so...use Wix p/n 58846. it's both filters.
http://www.wixfilters.com/filterlook...&TempYear=2009
Old 09-06-2011, 08:22 PM
snrusnak's Avatar
Rep:1388
Thanks buddy! That helps
Sean
Old 09-07-2011, 03:50 AM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1230
So I have confusion/issues now with this trans service...
I went to autozone to buy the trans filters and such and here's what came up in the computer:
2010 Dodge Truck RAM 1500 SLT 2WD
8 cylinder 287/Q4704 P 4.7L Flex Fuel
Duralast
Part # TF164
This one was a single filter (the flat one) and a gasket
or
8 Cylinder 345/Q5654 T 5.7L SFI Hemi OHV
Duralast
Part # TF349
This one was both filters (flat one and oil filter looking one) and I think also a gasket
I used TF 349. The transmissions are identical, except for the bolt pattern on the bell housing and the size of the input shaft.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 09-07-2011, 07:49 AM
snrusnak's Avatar
Rep:1388
Thank you too! I'd like to do this this weekend so I'll probably go with the duralast one, as they have it in stock down the street. Do you think the wix one is anything better? Also, the kit came with a gasket....did you just not use it?
Sean
Old 09-07-2011, 10:30 AM
ArmyofOne's Avatar
Rep:1230
some kits do come with one, some dont. The trans does not REQUIRE it.i personally prefer gaskets...but the 09's dont use them at all. 10's were hit and miss, 11's use one.
Dealerships: A User’s Guide RootBeer Dodge Ram Knowledge Base 3 05-04-2012 05:03 PM
Trans rebuild 94ram1500 5.2L V8 Specific Topics 4 04-07-2011 09:49 PM
$3,500+ in trans repairs,etc still no fix HELP! rcs4787 5.2L V8 Specific Topics 5 11-17-2010 02:48 PM
My trucks flashing a P0420 and a P0442 code jcasey10 5.9L V8 Specific Topics 10 09-15-2010 02:10 PM
i want to do a trans conversion from auto to manual off road guy 5.9L V8 Specific Topics 1 12-16-2008 08:00 PM
