Old 09-02-2011, 07:11 PM
elund08 elund08 is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: SLT Reg. Cab 4X4
Color: Almond Metallic Pearl
elund08 is on a distinguished road
Default Starting Issues
My 03 4.7 has been having a hard time starting while cold. I have to crank the engine for an extended period of time to get it started. Sometimes 4 to 5 times longer than a warm engine.
I installed a flowmaster muffler a few months ago, and cleaned the throttle body ( using brake cleaner), and new plugs.
Any ideas, Thanks.
Erik
Old 09-02-2011, 07:44 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
Try to Clean the Fuel system. start with seafoam there many video's on youtube on how to on our trucks. If the problem continue do a Diagnostic check and see what it tells you.
Old 09-08-2011, 07:10 PM
02Ram4x4 02Ram4x4 is offline
Vehicle: 2002 Ram
02Ram4x4 is on a distinguished road
the brake cleaner to clean your TB is not a good idea, it contains inorganic material that wont burn clean in the cylinders you would need alot to create problems but still a bad choice, use sea foam deep creep its petroleum based and burns completely no residue. also check the obvious like dirty fuel filter, when did you run a good fuel system cleaner, and what type of gas you purchase.
Old 09-08-2011, 07:49 PM
Rep:12
I agree with 02Ram4x4 100%
Old 09-17-2011, 08:17 PM
I removed the throttle body before cleaning with the brake cleaner. The problem started a couple months after this service.
I dumped in a can of seafoam to a 1/4 tank of 87. No change.
Symptoms still persist. No CEL.
Old 09-18-2011, 09:10 PM
Vehicle: 2002 Ram
get the fuel pressure checked, at startup and while running and under load, then have a vacuum test, all these tools can be purchased at harborfreight for a good price, and a haynes manual can give you specs you need to find the issues.
Old 09-23-2011, 07:41 PM
A fuel pressure test showed a drop in pressure after engine shut down.
I will be replacing the fuel pressure regulator.
Thanks!!!
Help! desperate, 2003 dodge starting issues!! janruss1999 Cummins Diesel Specific Topics 12 04-30-2012 02:35 AM
Tranny Issues??? blacky454 5.7L (345 cu in) HEMI V8 Specific Topics 2 08-20-2011 01:15 AM
Feathering issues with Stock Goodyear Wranglers Turbovsix Dodge Ram Wheels And Tires 9 08-14-2011 02:02 PM
01 Ram Quad 4x4 - Morning Starting Issues Paffer Electrical 5 07-02-2011 02:02 AM
does dodge ram have issues with rear ends on there trucks ? nitro1965 5.7L V8 Specific Topics 9 04-17-2011 11:03 AM
