puddle light removal - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 09-02-2011, 08:58 PM
FlashSmith101's Avatar
FlashSmith101 FlashSmith101 is offline
Vehicle: 2009 Dodge Ram 1500 Sport Hemi
Color: Electric Blue
Rep:23
FlashSmith101 is on a distinguished road
Default puddle light removal
my puddle lights (L.E.D.s) went out and im trying to get access to it but i just cant seem to find a way in to that clear cover where the lights are held....any help gettin in them pleaseeeeee?????
Mods- Diable Predator Sport (set on 91 octane), Air Raid CAI, Aero Turbine exhaust, 24in Boss Motorsport rims (painted white), Cut back springs(leveled), color matching blue dash and features, white emblems and grille, 180 t stat, P.A. system, all LED lights.
Old 09-03-2011, 12:08 AM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
They are a sealed unit. Hope your still under warranty.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 10-03-2011, 08:11 PM
jtodt jtodt is offline
Vehicle: 2011 Dodge Ram 1500
Rep:38
jtodt is on a distinguished road
LEDs usually will not burn out. It may be an electrical issue. If it is both sides, I would check to see if you have power to the mirrors. It could be a fuse or bad connection. Hope this is useful.
Old 11-19-2011, 06:17 PM
caswell239 caswell239 is offline
Vehicle: 2011 Ram 1500 Sport Crew
Color: Deep Water blue pearl
Rep:20
caswell239 is on a distinguished road
... maybe some super special LEDS wont burn out but i see them burn out all the time. they a have longer life span but they still will burn out. BUT if they are both out at the same time then yea most likely an electrical issue
Old 11-19-2011, 07:26 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
like said above its a sealed unit and the actual lights cannot be replaced it has to be the full unit that gets replaced and more than likley you will get the full mirror replaced if your under warranty still.....iv had both my mirrors replaced because of this same issue
Old 11-19-2011, 08:31 PM
col's Avatar
col col is offline
Vehicle: 2012 Ram 3500 CCSB
Trim Level: Laramie Longhorn
Color: Black & Gold
Rep:92
col will become famous soon enough
sorry guys but its not a sealed unit. i had mine swapped out while i was sitting in the truck at the dealer. took about 10 mins.
2012 3500 Cummins Laramie Longhorn CCSB | 68 RFE | Black over Gold | RaceMe Pro Tuner | Flo pro 4" Stainless Steel Turbo Back Straight Exhaust | 5'' S/S Tip
Old 11-19-2011, 08:54 PM
col's Avatar
col col is offline
Color: Black & Gold
Rep:92
all done by just popping off the mirror glass....
Old 11-20-2011, 01:29 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Check out this thread - http://www.ramforumz.com/showthread.php?t=94302
Post #7 might be of some help.
brad
Interested in one of my mods?
Old 11-20-2011, 01:29 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
I just pushed my mirrior all the way in from the bottom and the clear part clips in so a little finesh and it comes right out took mine off the tint them.
Old 11-04-2014, 12:30 PM
Lonecoyote69's Avatar
Lonecoyote69 Lonecoyote69 is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Trim Level: SLE
Color: Saddle Brown
Lonecoyote69 is on a distinguished road
It won't be electrical wiring issues the lamps will crack and water gets in and corrodes the actual lamp assembly. Simply get news and prior to installing them coat the top side with clear silicone and cover with a piece of Saran Wrap and. Pop in place. Don't wash truck for a day or two and voila last set U will buy. Too bad dodge doesn't know how to fix this. I am heading in for my warranty set now and will take them out and seal as they said they won't do it. Duh!!!!!!
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 18 06-09-2017 09:33 AM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
side Mirror Signal / Puddle LED Removal riggz Body & Interior 3 07-31-2011 09:24 AM
Factory fog light removal ram4x4 2009 Dodge Ram Forum 9 06-05-2010 08:53 PM
