Old 01-30-2012, 11:13 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
I do believe that is the latest for the 730N but I will send out an email on it tomorrow and get back with you on it. ok
Originally Posted by customstar00 View Post
xsdbs,
Can you confirm this update? I have found the 2.120 update for the RHR on the mygig forum.
http://mofv.com/mygig/BBS/viewtopic.php?f=9&t=5447
Old 01-30-2012, 11:19 PM
Rep:73
The update that I listed in post #40 will work for your vehicle. Download it and apply it.
Originally Posted by joeCs View Post
Where can I download this SW update for my 2011 Dodge ram Sport with the RBZ radio?? Thank you very much for the help!
Old 01-31-2012, 06:29 PM
Rep:73
Yes this is the most current SW update. There's also another thread on this forum where they've applied it.
http://www.ramforumz.com/showthread.php?p=708858
xsdbs,
Old 02-01-2012, 12:02 PM
Ruff's Avatar
Ruff Ruff is offline
Vehicle: 2011 Ram 2500
Color: grey
Ruff is on a distinguished road
Hey XSDBS,
can't pm as of yet, couldyou send me the uconnect update to my temp email, gruffer@yahoo.com? I have a 2011 ram 2500 with the 430N RHB.
i really appreciate it
Old 02-03-2012, 12:32 AM
Rep:73
sure, I can do that. (just sent it for you). I also posted the link in post # 40. Let us know how it works out for you.
Originally Posted by Ruff View Post
Hey XSDBS,
Old 02-04-2012, 10:18 AM
joeCs joeCs is offline
Vehicle: 2011 Dodge Ram Sport
Color: Mineral Gray metallic
joeCs is on a distinguished road
Thanks!
Old 02-05-2012, 01:42 PM
Jimmy's Avatar
Jimmy Jimmy is offline
Vehicle: 2011 Ram
Rep:52
Jimmy will become famous soon enough
I would be glad to help you out, I need an email to send the file to and I'm sure that you don't want to post your personal email on the forum (I'm not saying anything would happen from the fine member that we have here but...) If you want to set up an email just for this and then shut it down after we get you taken care of that would be ok.
Well let's try this instead. ( I am new with this stuff and hope this works.) I just loaded it on Mediafire.
******NOTE to anyone that also decides to use this file. This particular file is for vehicles with High Speed CAN BUS, which is most of the vehicles, including the Ram.
http://www.mediafire.com/file/qzfm7w...m/uconnect.upd
fingers are crossed.
Here's the Uconnect update and instructions:
Download it to a thumb drive that has no other files on it. If you have files on it, please delete them and format the drive (to FAT32) just to make sure that it is completely clean.
Turn the radio on, Place the thumb drive in the center console USB connector (on vehicles with the dealer installed unit, it should be in the glove box), press and hold the Uconnect button for about 12 - 15 seconds, you should here "update started". This process should take about 15 - 20 minutes, there will be some beeps during the process. Please listen during the update for any error message that may be said by Uconnect. When the update is completed, the radio screen will go back to a radio display. Now plug in your iPhone or iPod and let it be read by Uconnect, does it start playing after being read? Let me know how this works out for you.
I installed this update today, and have lost all power to the usb port in my glove box. The uconnect buttons don't seem to work any longer, as well, the bluetooth will not connect to my phone. Any suggestions?
Old 02-05-2012, 06:19 PM
Jimmy's Avatar
Vehicle: 2011 Ram
Rep:52
Does anyone know if the uconnect update can be done from a cd instead of the usb? Since attempting this update earlier today, my usb in the glove box no longer has power so I am unable to attempt an install from the usb. I was wondering if I could burn this file to a cd, and update from the head unit itself?
Old 02-05-2012, 06:48 PM
Rep:2657
It sounds like you did what i did
I interrupted the download, i had to take the key out of the ignition to go inside to answer my phone, a client needed me to do a job immediately.
I thought that i had fried my radio
you won't believe this, but first i tried turning the key on & off a few times, started pushing buttons as well. I finally remembered that the radio is some how connected to the Climate Control Fan, so i added that into the mix, it finally rebooted. The download restarted, i left the ignition on & locked the truck with the spare key, while i got ready to go do the job. When i came out, the radio screen read download complete
Old 02-05-2012, 07:12 PM
Jimmy's Avatar
Vehicle: 2011 Ram
Rep:52
The radio still works, and I was able to do the satellite update after this. The only issue I am having is the glove box usb doesn't work (won't even power on a usb stick or ipod), and the uconnect buttons don't respond to anything. The radio works other than this (I can use satellite radio, cd's, and the hard drive). Without the use of those buttons, and the usb in the glove box, I am unable to update uconnect.
quick fix for streaming bluetooth audio to mygig w/ iphone or ipod slikkwilly002 Dodge Ram General Discussion 1 09-04-2011 01:44 PM
