Old 09-03-2011, 12:01 AM
Bighert3rd's Avatar
Bighert3rd Bighert3rd is offline
Vehicle: 2011 Ram 1500 Sport (HEMI)
Trim Level: Sport (HEMI)
Rep:60
Bighert3rd will become famous soon enough
Default Wheel spacer/adapter installed
I wanted a more aggressive stance on the RAM so I decided to get me some 1 3/4 inch spacers (apapters)...whatever you want to call them. Going with 1 3/4 inch allowed me to use without having to cut the wheel studs. I like the look even though the wheels stick out a bit. Like I said it just gives it a little more aggressive look than with the wheels flush with the wheelwell. I got hub-centric spacers from wheeladapter.com...here is the direct link:
http://www.wheeladapter.com/dodge_wheel_spacers.php
Install was a snap and I ensured to use RED locktight. Ride is still as smooth as before putting them on. I haven't seen these used on the stock wheels anywhere online so figured I would share a few pics. I will take some better photos later outside. I just finished and it's almost 11:00.
Mods: Sport Hood-True Duals with Magnaflow 14'' mufflers-magnaflow 4'' tips-Magnaflow X pipe-Airaid CAI-PowerAid TBS-Truxedo Low Pro Cover-In Channel Vent Visors-22'' 2 Crave Wheels
Old 09-03-2011, 12:59 AM
Porter_'s Avatar
Porter_ Porter_ is offline
Vehicle: 2011 Ram 1500 4x4
Rep:39
Porter_ is on a distinguished road
i'd be curious to see if you have any long term effects from this. i'm considering 1/4" spacers so i can fit a set of 305/55/20 tires on. i'd be a bit cautious of 1.75" spacers. you're introducing a moment into the load-path that the suspension was not necessarily designed to take.
assuming 5500 lbs equally distributed to the 4 wheels, which is conservative:
(5500 lbs/4)*(1.75"/12) = 200 ft-lbs of moment at each wheel
2011 Ram 1500 Big Horn 4x4 5.7L
1.5" TGC Leveling Kit, 305/55/20 Toyo Open Country A/T's
Old 09-03-2011, 08:42 AM
Dak2 Dak2 is offline
Vehicle: 2011 RAM 1500 QUAD CAB 4X4
Dak2 is on a distinguished road
I would be more concerned about bearing loading (premature bearing
failure) and body damage with crap being thrown up.
Dak2
Old 09-03-2011, 10:54 AM
Bighert3rd's Avatar
Rep:60
Yea hopefully won't cause any major issues. What's the difference between doing something like this and just putting wider tires on? Wouldn't wider rims produce the same strain on the bearings??? I'm not an expert in rim designs and would assume they are balanced, but I would think anything other than a stock setup would produce premature damage eventually to include different rims, lifts, adapters, etc.
Old 09-03-2011, 10:57 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Ive had 1.75" adapters on for atleast 20k miles now with a leveling kit and just started to get a clicking (front axle U joint on the drivers side I think). I would much rather have an offset wheel but they arent in the budget. I take the wheels off and double check torque every few thousand miles and have yet to find a loose stud
Old 09-03-2011, 10:58 AM
Color: Mineral Gray
Rep:177
I do have a set of flares that are waiting to be painted though
Old 09-03-2011, 11:38 AM
Bighert3rd's Avatar
Rep:60
Did you have the same spacers as me...from www.wheeladapter.com?
Old 09-03-2011, 12:42 PM
These truck suspensions and bearings are designed to use wheels using +25mm offset, you can probably go as far as +12mm offset without causing undo stress, a 1.75 inch spacer takes you effectively to a -19mm offset.
I have talked to several Mech Engineers at work and this was what they suggested. As far as wider rims it would not be a problem as long as the offsets remained in the +12mm to +25mm category.
That's my story and I'M sticking to it
Dak2
Old 09-03-2011, 01:29 PM
cyberpine cyberpine is offline
Vehicle: 2010 Dodge Ram Quad Cab Hemi
Rep:53
cyberpine will become famous soon enough
Originally Posted by Dak2 View Post
These truck suspensions and bearings are designed to use wheels using +25mm offset, you can probably go as far as +12mm offset without causing undo stress ...
If true it's a damn shame.. and the way Dodge designed the suspension on these trucks there are all sorts of obstructions that keep us for mounting even a 12.5 inch wide tire on stock.. which is bullshit for a powerfull V8 full size truck.
I've been discourged by two shops now not to change the offset in any way on my plastic 20 inch wheels for the same likely valid reasons.
I've been keeping an eye on my cheap factory goodyears and thinking of moving to 305/60/18s on 18x9 rim with +0mm offset.
I suspect i'll be fine.. but I'd like to take a moment to piss on a few Dodge engineers while I consider options
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 09-03-2011, 02:43 PM
Color: Mineral Gray
Rep:177
mine aren't hubcentric, its really hard finding 8 lug hubcentric adapters and for the price it's cheaper just to buy wheels
4 wheel drive engagement IvanSunn 5.2L V8 Specific Topics 3 03-08-2012 09:58 PM
Wheel Hub Assembly 1998 Ram 2500 write up. Zac2109 Dodge Ram Wheels And Tires 1 06-24-2011 08:29 AM
Bubbling paint around rear wheel well 1BigHemi Body & Interior 18 09-08-2010 08:41 PM
Wheel Spacers causing severe Wheel Wobble nantuzzi Dodge Ram Wheels And Tires 3 06-10-2010 10:17 PM
Wheel Choices - Get Your Vote On! erm Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 33 11-12-2009 03:56 PM
