Old 09-03-2011, 01:35 PM
Gossage55 Gossage55 is offline
Gossage55 is on a distinguished road
Default Antifreeze question
Can someone help me out on this? I have searched and found several different answers as to how many gallons of antifreeze a 5.2l engine will take. Some say 2 and some say as much as 5 gallons. I'm going to be flushing the radiator soon and need to find out. Also should I change the thermostat as well?
I've got a 1997 Ram 1500 2wd
Thanks!
Old 09-03-2011, 02:12 PM
Rep:2625
cooling capacity is 17 quarts fluid in the 1997 5.2, IF you have the 3 core radiator, that is the largest radiator that was available, it could be a bit more
as for the thermostat, that is a decision that i could NOT make, without seeing it
I would advise that if your hoses & belts are about 5 years old, check the belts for cracking on the wear side, depending on the type hose that you have, at the curve, take your finger & thumb & squeeze, if you feel anything like a crunching, it is likely a spring inside the hose that has seen better days. The spring holds the curved part open, if it wasn't there & the water heats up, the hose would collapse. The spring gets old & it begins to rust & then breaks, the pieces go in places it doesn't belong
Old 09-04-2011, 02:12 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
according to the owners manual coolent cap is 20 qts or 5 gal.
antifreeze, which kind/brand??? got hemi Dodge Ram Detailing and General Maintenance Forum 12 12-08-2012 04:47 PM
Serious Antifreeze smell sfcb 4.7L PowerTech V8 Specific Topics 4 07-07-2011 11:37 PM
coolant line question 97ram1500 Heating & Cooling 1 09-28-2010 05:18 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 09:31 PM
Smell Antifreeze on Start-up dodgeramowner2002 4.7L PowerTech V8 Specific Topics 1 05-21-2009 12:03 AM
