Old 09-03-2011, 06:00 PM
JR23 JR23 is offline
Vehicle: 2003 Quad Cab 2wd 5-speed
Color: Maroon
JR23 is on a distinguished road
Default Upgrading from factory bulbs
Need some good advice on upgrading from the factory headlights and fogs now that i have one burned out. I have used silverstars in the past but did not get much life out of them for the price. I definately want to match heads and fogs. Looks silly having 2 different colors from your lights, but do want to upgrade from the factory. Thanks for the feedback, its been awhile since I've been on here. Luckily my truck has been doing great and just turned 122K!
Old 09-03-2011, 06:31 PM
Crash Crash is offline
Vehicle: 2016 Laramie Longhorn Limited
Trim Level: Laramie limited
Color: Black crystal pearl
Rep:404
You want real light output look into hid kits. for you gen ram you should be able to buy plug and play kits for lows and fogs and never have to turn your highbeams on again
Old 09-03-2011, 06:41 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1276
+1 Crash nailed it! I just went through the hassle of upgrading halogen bulbs from Putco's to PIAA's then finally saying enough was enough and went HID. Never again will I go with halogens, from here on in all vehicles will get modded to HID's!
Big Red my old 2011 Sport
Old 09-03-2011, 08:49 PM
I agree...once you go with a set of HID's you won't ever want to go back to halogens.
Old 11-23-2011, 02:03 PM
Tpellus Tpellus is offline
Vehicle: 2003 Dodge Ram 1500
Color: Dark Pearl Red
Tpellus is on a distinguished road
What HID's do you guys recommend? How much does replacing the headlights and fog lights run? I want to change mine but I do not want to have to change out my entire headlight. Just wondering if you are able to just plug in new bulbs and that is it?
Old 11-23-2011, 10:33 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
i am working on a post with bulb #'s for all rams but the easiest upgrade that doesnt blind oncoming traffic is to modify high beam bulbs to fit low beam sockets. i did my 4th gen a while back and it made a night/day difference. all u have to do is remove the tabs off the high beam bulb and its plug and play. all low beam bulbs have a similiar high beam counterpart that doesnt have a painted tip and usually has a little higher wattage. my 4th gen has an h11 low beam and now it has h9 bulbs that give me far more light output reliably.
Too many mods to fit here!
Old 11-24-2011, 02:26 PM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2015 Crew Cab 1500 Sport 4x4
Rep:19
blackpearldodge is on a distinguished road
You do not have to replace the headlight assembly to install HIDs into your truck. I paid CDN$130.00 for my HID kit (no fogs.)
There are several brands to choose from...lots of information on this site from other members as to the pros and cons of kits. One that has received a lot of attention is a kit from DDM Tuning. I was very close to purchasing from them, but I went elsewhere after reading what others here had to say about them.
Do your research so you won't be disappointed later.
As for blinding on-coming traffic: I've had my lights in for just under 2 months and I have yet to be high-beamed. FYI: I did aim the driver's light down a bit so it met up with the passenger light.
Good luck.
Once you have Black you'll never go back! Hmmmm.....well... now that isn't quite true. I went back to WHITE!
Sport Performance Hood, OEM Mud Flaps, Factory Spray-in Bed Liner, CREE MK-R LED Fog Lights
Old 11-24-2011, 02:32 PM
Rep:19
Amen to that.
This is my second truck and my second set of HIDs.
The stock lights in my Dodge Ram were horrible. The light was so bad at times I didn't feel the headlights were on. If it weren't for the fogs (after-market halogens) I wouldn't have had any light on the road. It was terrible.
I was very reluctant to switch over to HIDs in my Dodge because of all the problems members were/are having.
Now, I have had some issues (though minor) with light flicker and bulb-out. No EVIC warnings though, and the TPMS light doesn't seem to be coming on anymore. I've only had a misfire twice in the time the lights have been in.
Another member here told me it is not un-common for a ballast to miss-fire. And I can't say for sure if I am still getting flicker on ignite. I know I was getting flicker before I disabled the "Flash lights with unlock". That is also when I had my first bulb-out occur.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 16 07-02-2016 05:36 PM
Installing Factory Brake Controller brc3858 2010 Dodge Ram Forum 17 05-07-2013 08:02 PM
Upgrading Speakers on Factory 4th Gen 5 speed Custom Dodge Ram Interior Modifications - Custom Audio / Video 9 08-21-2011 07:30 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Factory installed bulbs. Big Daddy 2010 Dodge Ram Forum 0 05-08-2010 09:35 PM
