Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 09-04-2011, 02:42 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Default Bowing brake lines/ABS light
my dad has a 95 2500 4x4 i've replaced the back line from the divider block behind the left front tire and bled out the whole system but now it blew one of the front lines at the divider. have not found if its from the booster or to the right wheel. but now not only dose it leak like crazy but the ABS light is on. Will i have to take it in to have the code cleared when i fix it? or will the computer clear on its own then it no longer picks up a pressure drop? any tech help will be help.
Old 09-06-2011, 07:08 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
I'm thinking that you should also have a brake warning light, but I digress... Once you get the air out, you should be light free, if not, crack a line or bleeder on the other half of the system, to force the plunger tripping the light to the opposite end of its travel, then bleed the other side off a little til the lights are off. Once you get a feel for how much juice it takes to move the divider plunger to the middle, it'll be a snap. There used to be other ways to force that thing to center, but this works for me and the old iron I drive, theres a lot more power in hydraulics than there is in my hand pushing pins back and forth.
3rd brake light leak fix snrusnak Dodge Ram Knowledge Base 100 11-16-2015 01:34 PM
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
abs light, brake light, speedo not working, stalls when stopping B and B LANDSCAPES Electrical 21 04-07-2011 10:56 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 03:33 PM
= Copyright a Network Site =Ad Management by RedTyger
