Old 09-04-2011, 07:05 PM
WeirdDeere WeirdDeere is offline
Vehicle: 2001 Dodge Ram
WeirdDeere is on a distinguished road
Default 2001 Ram 2500 stalling while warming up at idle
Been trying to figure out this issue and it's driving us nuts. Have a 2001 Ram 2500, with the 5.9, and auto tranny.
When cold...the truck starts up fine, idles great.
When it's just starting to get warmed up, the idle goes slower and slower, to the point where it will stall. If you start driving at this point, it will run, but will occasionally spit back up through the valve body.
BUT....when it gets fully warmed up, it starts running great again, no issues at all!
There is no check engine light, no codes from our reader. Fuel pressure is fine. Even checked the TPS and it seems to read steady and fine as well.
Any help on trying to figure this out would really be appreciated!
Old 09-09-2011, 01:15 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Welcome to the site; I don't have an answer so, it's time to .................... this back to the top! Drop by the Newbie Checkin and introduce yourself. Hope to see you around!
Old 09-09-2011, 05:11 AM
Thanks for the bump, this one is really a head scratcher!
Old 07-12-2012, 04:42 PM
1998ram2500 1998ram2500 is offline
Vehicle: 1998 Dodge Ram 2500 5.9 gas
Color: Green over Silver
1998ram2500 is on a distinguished road
Default Any solution?
I have a 1998, 2500 with the exact same problem. Any clues would be appreciated.
Thanks
Old 07-13-2012, 09:13 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Check and clean idle air control at back of throttle body. Next check air temp sensor its in intake behind alt. Its usualy gray with two prong plug.
Old 07-15-2012, 01:19 AM
Thumbs up Solved
I did alot of internet searching and finaly found a post by a Dodge mechanic that solved the issue. The upstream O2 sensor was bad. He explained that the engine will run fine for upto 2 minutes and then take a dump and maybe even stall, but then once warm will run fine. The problem is not the IAC as it is only doing what it is told, but the O2 sensor that is telling it to do the wrong thing.
I replaced my upstream O2 sensor ($60 part) and problem was intantly fixed
I hope this helps the next guy.
Corey
Old 07-15-2012, 05:51 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Sweet. Thanks for another soluton.
Weird Errors and rough idle / stalling JayDee240 4.7L PowerTech V8 Specific Topics 2 09-01-2011 12:38 AM
2003 and later front brakes on a 2001 and older 2500 WVdieselOwner Newbie Checkin! 7 04-04-2011 10:31 AM
Stalling in cold weather. Air Idle Valve? Todd F 5.9L V8 Specific Topics 3 12-06-2010 10:12 PM
2001 2500 5.9 Magnum Cooling Issues? TheLoyale 5.9L V8 Specific Topics 2 12-05-2010 02:09 PM
2001 2500 Long box conversion cvicsi Dodge Ram General Discussion 3 12-17-2009 12:13 PM
