Old 09-04-2011, 08:53 PM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
Default How to clean crankcase..
Changed out my oil today with mobile 1 and wix filter, but I noticed the oil was very black and dirty. This is my first change since I bought the vehicle from the dealership (used). Anything I can do to help clean out old crud?
I know there is an argument for and against Seafoam, what are the other options?
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 09-04-2011, 09:18 PM
Rep:2664
I am against any crankcase additive
That being said, if your oil at the next change is as bad as the last time
putting Seafoam into the crankcase a couple hundred miles before the change shouldn't hurt
I wouldn't even think about doing it on something that has 80,000 miles on it & it was never done before
but that is just me
Old 09-04-2011, 09:28 PM
Drake371's Avatar
Rep:83
Well I don't know the past history very well, as it was used and all highway miles. It had 91K on it... I just didn't like the look of that nasty oil... I'll be checking it a tomorrow after i get done driving around town... to see how nasty it became, but I really wanted to clean the crankcase out asap and do another oil change
Old 09-04-2011, 09:41 PM
JumpSteady JumpSteady is offline
Vehicle: 2015 Ram 1500 4x4 quad cab
JumpSteady is on a distinguished road
You are cleaning it, every time you change the oil. When the oil comes out dirty, that means the detergents in the oil are working.
Old 09-04-2011, 09:50 PM
Drake371's Avatar
Rep:83
I understand that much, but it is possible that it is so dirty that it might take several oil changes to get it out... I would like to speed up the process if possible
Old 09-16-2011, 07:47 PM
Drake371's Avatar
Rep:83
Well just did another oil change at 400 miles... mobil 1 5w20 and K&N filter this time... Oil was still black, but not pitch black like it was before..... so I am guessing my crankcase is still filthy inside... and I didn't do any additives
I guess next change I should just drop the oil pan and clean that out by hand ... at that point might as well buy the oversized pan like I wanted to do.
Old 09-16-2011, 09:02 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
have you found a larger oil pan? I haven't seen any. maybe a couple of short interval oil changes with some cheaper dino oil until it starts coming out cleaner. yeah, I guess dropping the pan and wiping it out might help too.
do you do a lot of short trip driving?
Old 09-17-2011, 11:34 AM
chambers chambers is offline
Vehicle: 2004 Dodge Ram 1500
Rep:29
chambers is on a distinguished road
Marvel mystery oil and dino oil can be used to clean it up. Running any synthetic like Mobil 1 will help clean it out, it just might take a few changes. Pennzoil platinum and ultra are both supposed to be very good at sludge cleanup, so you could use those and make sure you use a good filter like wix, mobil 1, k&n, pureone, or bosch distance plus and that will also work. You should also check your pcv valve, it should probably be replaced if it hasn't already been. Also make sure your air filter is in good shape, don't want dirty air getting into the engine or oil.
Old 09-23-2011, 11:42 AM
Drake371's Avatar
Rep:83
I did the oil change before I want to Boston, once I got up here, (1900 miles) I did another oil change, planning on doing another change once I get back south. If the oil is still dirty as hell, I'll change out the pcv valve (didn't think to check that) and put some marvel mystery oil in... I think its slowly getting cleaner, didn't get a chance to see the oil during this last change.... next one I be in my trusty old garage or mech shop.
Old 09-23-2011, 12:09 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
I would pull the pan and clean if it bothers you that much. You may have a lot of sludge built up in there. And I wouldn't put any more additives or cleaners in there with that many miles on it. Now it's going to take a few oil changes to get the cleaners out. If there's sludge in it, it now becomes sludge/cleaner that will mix with every oil change utill you get the cleaner out. So either drop your pan and clean it or do a couple of more early oil changes without any additives. edit: I don't think the PVC valve is gonna make that big of a difference as far as the dirty oil goes. It's a good idea to have a fresh one, but don't expect the oil to get any cleaner because of it.
clean brake fluid rez on truck? spockmckoy Dodge Ram General Discussion 10 06-06-2011 12:22 PM
How can I tell if I have all teh parts for Sirius radio? Hermosa Dodge Ram General Discussion 6 05-27-2011 12:16 PM
Yet another review: Mr. Clean Auto Dry 98sst Product Reviews 10 03-09-2011 06:09 PM
How many coils to cut to get 2"-2.5" drop????? DodgeMyRam Suspension 1 03-02-2011 03:43 AM
How fast can we go racerx9987 2011 Dodge Ram Forum 15 02-28-2011 11:36 PM
