Old 09-05-2011, 06:03 PM
Todd GTO Todd GTO is offline
Vehicle: 2000 Dodge ram 1500 4x4
Trim Level: SLT Laramie
Todd GTO is on a distinguished road
Default Front & rear axle/transfer case fluid change recommendations
Hello all,
I just bought a 1 owner 2000 Ram 1500 4x4, it seems it was well loved and taken care of.
I want to change the fluid in both axles and transfer case, what type/weight, additives are required? How much of each?
Thanks, Todd.
Old 09-05-2011, 06:12 PM
2kram 2kram is offline
Vehicle: 2000 ram 1500
2kram is on a distinguished road
It's time to get a haynes manual. Has all the info you'll need and more. For what it's worth, i went synthetic in both diffs (use additive for limited slip diff), nice clean atf in the transfer case. While your at it give the chassis a good lubing.
Old 09-05-2011, 06:22 PM
Rep:2657
use any brand fluid that you trust, synthetics are good
this is a website that is usually correct
http://dodgeram.info/tech/BRSpecs/fluids/specs.html
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
Major breakdown!!!! Transfer case, tranny, drive shaft, rear diff..... MRP 2010 Dodge Ram Forum 28 06-22-2011 05:13 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
Rear Diff fluid ?? trainplanemech Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 04-03-2010 09:29 AM
Front and rear differential servicing dirtsurferus Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 5 09-26-2009 08:55 PM
