Problems running when first starts up - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 09-06-2011, 04:56 PM
FlyRacing181 FlyRacing181 is offline
Vehicle: 2006 Dodge Ram 1500
FlyRacing181 is on a distinguished road
Default Problems running when first starts up
Hey guys I had just bought my first Dodge a few months ago, it is a 2002 Ram 1500 SLT with the 5.9L Engine. Whenever I would leave the truck sit over night or for a few hours I would go to start it up..It starts up fine with no problems what so ever, but a little after starting and I would go to drive it would like hesitate to go and the RPM's would drop super low almost like it is going to stall but it never stalls. Could this be like a Air/Fuel Sensor or something?
Any help would be greatly appreciated.
Thanks guys.
Old 09-06-2011, 05:04 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web.
I'm here to help you navigate the site so drop by the Newbie Checkin and say hi to everyone while you wait on the answer to the hesitation issue.
Old 09-06-2011, 07:23 PM
moparornocar72's Avatar
Rep:630
When was the last time the fuel filter was changed? If it looks old/dirty I would start with that. If it is clogged it is not allowing the amount of fuel needed when the accelerator is applied. Another cause could also be the solenoid in the starter on its was out or getting too hot and not functioning properly
14.268 @ 95 MPH Full Trim
Old 09-06-2011, 07:39 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
have you tried to pull any codes? even if the check engine light isn't on.
Old 09-06-2011, 09:59 PM
Hey guys..the guy at the Dodge Dealership said the fuel filter is attached to the fuel pump or something like that and I couldn't just buy the fuel filter?? I dont know ha. and no I didn't check any codes I will try that next. but yea my check engine light isn't on. But after it warms up after a little bit it runs amazing.
Old 09-06-2011, 10:48 PM
CHVYKLR's Avatar
Rep:252
here is a copy and paste from the service manual
FUEL PUMP MODULE
The fuel pump module assembly is located on the top of the fuel tank . The complete assembly contains the following components:
A combination fuel filter/fuel pressure regulator
A separate fuel pick-up, or inlet filter
An electric fuel pump
A lockring to retain pump module to tank
A soft gasket between tank flange and module
A fuel gauge sending unit (fuel level sensor)
Fuel line connection
The fuel gauge sending unit may be serviced separately. If the electrical fuel pump, primary inlet filter, fuel filter or fuel pressure regulator require service, the fuel pump module must be replaced.
Old 09-07-2011, 10:09 PM
haha so that means I am pretty much screwed and need to get that whole assembly? ha I love how they make everything attached to each other. Any idea what that would cost? not necessarily mopar I could get aftermarket also.
Thanks a lot for the info I appreciate it.
Old 09-07-2011, 10:21 PM
CHVYKLR's Avatar
Rep:252
I may have jumped the gun with my post above b/c I wasn't thinking. That copy/paste is from the 2009 manual. I did a quick google and I found this part for your year truck. So maybe your filter is replaceable but it still might be inside the tank...IDK.
http://www.drivewire.com/vehicle/200...0/fuel-filter/
http://www.partsgeek.com/gbproducts/...ek+Google+Base
Old 09-07-2011, 10:26 PM
CHVYKLR's Avatar
Rep:252
are you sure you need to replace it?
http://www.cargurus.com/Cars/Discussion-t22108_ds279567
http://www.justanswer.com/dodge/1mvs...-ram-1500.html
Old 09-07-2011, 10:55 PM
wlcmetomcyds wlcmetomcyds is offline
Vehicle: 1996 Dodge RAM 1500 Sport
wlcmetomcyds is on a distinguished road
I have a 1996 dodge ram 1500 and my truck too has the same setup as was suggested for the 2009, maybe its the same for all rams?
daytime running lights ladykiller Electrical 1 08-20-2011 10:25 PM
Problems with the Ram staying running jjklongisland LD RAM - General Discussion 2 07-13-2011 01:37 PM
intermitent slow start wont stay running issue ras119 Electrical 11 05-21-2011 09:07 PM
Truck cools at first, then starts to run warm RockByDefinition 5.9L V8 Specific Topics 15 06-10-2010 06:12 PM
2001 Dodge 3500 diesel problems zmantopdog Cummins Diesel Specific Topics 2 08-23-2009 11:42 PM
