Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 09-07-2011, 11:38 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
i would check the typical stuff first..change spark plugs, clean out throttle body, injector cleaner...
Old 09-07-2011, 11:44 PM
chefred112's Avatar
Rep:656
oh, here is how i changed my fuel pump...(comes with the filter, not a separate piece)
Old 09-08-2011, 03:19 AM
Bish Bish is offline
Vehicle: 2011 Ram R/T
Trim Level: Road and Track
Color: Deepwater Blue
Rep:32
Bish is on a distinguished road
FlyRacing I had a similar problem in a 2000 Dakota with the 4.7(208,000mi)... Do you get any engine surge when the motor about stalls? Does the problem clear up after the engine warms? I had a couple of bad sensors in mine (MAP and both O2 sensors), that cleared the problem for about 2 days then it started in on me again but only on cold starts. It just didn't wanna run till it got warm and then no problems. I was thinking maybe a Vac line somewhere and I was thinking fuel pump, engine light would come and go. I ended up trading in on a new Ram R/T which totally solved the issue.
Old 09-11-2011, 09:14 PM
FlyRacing181 FlyRacing181 is offline
Vehicle: 2006 Dodge Ram 1500
FlyRacing181 is on a distinguished road
@ CHVYKLR..I called the dealership and they said try running the Champion Spark Plugs because from 1999-2004 the Rams were built around those plugs and I put bosch plugs in. So I got new plugs, but havent gotten the chance to put them in yet. I dont know if this is going to work but Ill give it a shot. And he didnt say anything about a fuel problem when I talked to him so I have no idea if I need to change that or not ha.
Old 09-11-2011, 09:19 PM
@ Bish...haha yea trading it in would solve my problem, but I just bought this truck and I am in college so I am going to have to wait until i graduate to get a new one. and yea it would happen when i would first start it up then after 3-4 minutes it would run great. I have the R/T engine in mine.
Old 09-11-2011, 09:29 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
hope you get 'er running better! oh, and never trust that the new plugs are pregapped correctly.
Old 11-07-2011, 04:32 AM
BigH0ss's Avatar
BigH0ss BigH0ss is offline
Vehicle: 2013 Ram
Trim Level: Regular Cab 4x4
Color: Maximum Steel
Rep:122
Since you have an aftermarket intake I'd check that 1st. Make sure there's no restrictions and all the sensors are hooked up along w any vacuum lines.
Old 12-07-2011, 09:14 PM
mustard mustard is offline
Vehicle: 2003 Dodge Ram 1500 4x4
mustard is on a distinguished road
Stock 2003 5.9 4x4 64k miles with the same issues here. Truck starts up perfectly, then when it starts to warm up in the driveway it will stumble. Even if I immediately drive it, it will drive fine for a few hundred feet, then the engine will stumble and occasionally misfire. Once the truck is allowed to sit and warm up further, the issue goes away and the truck runs great. No check engine light either.
Changed the air filter and I added fuel injector cleaner to a brand new tank of fuel, no luck. Next step is plugs, wires, cap, rotor. We'll see..
Any other thoughts?
Old 12-12-2011, 08:01 PM
Welp I replaced the spark plugs, wires, and the distributor cap & rotor; the problem still persists. The only thing I noticed was that the cylinder 4 plug showed some oil. I might do a compression check later this week. Any other thoughts on what the problem might be?
Old 05-13-2012, 04:00 PM
1989doubleD's Avatar
1989doubleD 1989doubleD is offline
Vehicle: 1989 dodge ram dually
Trim Level: w 350
Color: clasic gray and black
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
1989doubleD is on a distinguished road
hi i have a 89 dodge ram and am experiencing the same thing i have to hit the gas to start and it hesitates when first started then goes away but still lacking power and half throttle
daytime running lights ladykiller Electrical 1 08-20-2011 10:25 PM
Problems with the Ram staying running jjklongisland Dodge Ram General Discussion 2 07-13-2011 01:37 PM
intermitent slow start wont stay running issue ras119 Electrical 11 05-21-2011 09:07 PM
Truck cools at first, then starts to run warm RockByDefinition 5.9L V8 Specific Topics 15 06-10-2010 06:12 PM
2001 Dodge 3500 diesel problems zmantopdog Cummins Diesel Specific Topics 2 08-23-2009 11:42 PM
