Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Dodge Ram Decals
Old 09-06-2011, 06:52 PM
Allstate48 Allstate48 is offline
Vehicle: 2010 Dodge Ram-1976 D200
Trim Level: SLT- Orange&rust
Color: Cool Vanilla
Rep:53
Allstate48 will become famous soon enough
Default Towing in 4th gear
Our truck has 3:55 gears. Hate them. When we tow our boat, even locked in tow, it shifts alot, I think. Will it hurt the tranny if I lock it in forth? We live in the hills, not mountains, just steep hills, and it drives me nuts to have it shift all the time. Thanks for the help. Doug
Old 09-07-2011, 04:10 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
If it feels like it's hunting for gears a lot that is hard on the transmission, should try to keep it from hunting.
Sean
Old 09-07-2011, 05:02 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2875
I don't tow, but i do travel at speeds much lower than most drivers, most times i have to travel at the same speed as the semi truck that i am paid to follow or lead
at certain speeds the computer is telling the transmission to shift up & as soon as it does, all the information is immediately changed & it tells the transmission to shift back down.
I manually select a gear that keeps it from cycling like that.
The only thing is that i sometimes forget to shift back into high gear when the road has leveled out more
Old 09-07-2011, 08:18 PM
dafoot dafoot is offline
Vehicle: 2011 Dodge Ram, 1500, Hemi
Rep:16
dafoot is on a distinguished road
I understand your frustration. My 2010 had 3:55 gears. My 2011 has 3:92s. I allways pull my 4500 lb boat in 4th gear. If I had to pull the boat in 5th gear, the Ram would have to go. Way too much shifting!
DAFOOT
Old 09-07-2011, 08:29 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Definitely use 4th. It will be a lot better for your trans to have it stay in a gear, rather then shifting all the time, and with 3.55 gears, your engine RPMs are well within a good torque range without reving to high.
Drop it to 4th, and enjoy the trip.
brad
Interested in one of my mods?
Old 09-08-2011, 05:27 AM
Color: Cool Vanilla
Rep:53
Thanks everyone. I have a 010 truck, and really like it, except for the gears. I just put too much faith in my salesman. Thanks Doug
Old 09-08-2011, 01:11 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
I have the 3:55's as well towing our 6000 lbs travel trailer. Yes it is not ideal, I thought they would be better, but I should have gone with 3:92, took what was on the lot at the time cause I did want to wait
I usually put it in Tow mode and lock into 4th when I am not on the interstate. At higher speeds (by that I mean no more than 65 mph) I put it in tow mode and leave it in 5th, in hopes I can save some mileage! Then ensure I change the transmission fluid and filter yearly and hope it last the 7 or so years I plan to keep it
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 09-08-2011, 01:26 PM
snrusnak's Avatar
Rep:1388
Just so you know, when in tow mode, "5th" as displayed on the evic is actually "4th". The trans rearranges gears when in tow mode:
Regular:
1st 3.00:1
2nd 1.67:1
2nd Prime 1.50:1 (used for downshifting only)
3rd 1.00:1
4th 0.75:1
5th 0.67:1
Tow/haul mode:
1st 3.00:1
2nd 1.67:1
3rd 1.50:1
4th 1.00:1
5th 0.75:1
Sean
Old 09-08-2011, 01:28 PM
snrusnak's Avatar
Rep:1388
Both 4th and 5th (regular) are overdrive gears. To technically lock it out of overdrive when towing you would not only have to put it in tow/haul mode (this locks out 5th), but you would also have to press the +/- button down to read "4" so it is in the 1:1 gear. If the trans is not hunting for gears there's no need to lock it out.
Sean
Old 09-08-2011, 01:45 PM
Rep:16
Yep..When it comes to buying trucks.....you need to know more than the salespeople. I too made the same mistake on the 2010. I bitched and bitched untill the dealer gave me a good deal on a 2011.
DAFOOT
Noisy Towing dancer 2010 Dodge Ram Forum 3 09-05-2011 09:36 PM
98 5.2 5speed manual weak towing and no power at all in 5th gear...problem or normal? altezzas14 Towing 11 07-09-2011 01:10 AM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
Backlash setting ccdelay 5.2L V8 Specific Topics 1 09-06-2010 12:02 PM
rear diff philjohn 4.7L PowerTech V8 Specific Topics 26 06-27-2010 09:09 PM
