Home-made cold air intake? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 09-08-2011, 04:33 PM
USMCLcpl0311's Avatar
USMCLcpl0311 USMCLcpl0311 is offline
Vehicle: 1992 Dodge Ram D250
Trim Level: Dunno?
Color: Grey
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
USMCLcpl0311 is on a distinguished road
would I need 4" for my 92 D250?
2001 Toyota Solara- Wife's car. 1992 Dodge D250 Cummins Diesel-THE GREY FOX! I FINALLY HAVE ONE!
Old 09-08-2011, 04:43 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
You'd want it to be at least the same diameter as your throttle body diameter, anything else would be restrictive.
Sean
Old 09-08-2011, 05:22 PM
Trim Level: Dunno?
Color: Grey
Well I have a turbo diesel not a gasser.
Old 09-08-2011, 08:21 PM
snrusnak's Avatar
Rep:1388
Well same concept.....Whatever your throttle body diameter is, don't go any smaller than that or it will be restrictive...
Sean
Old 10-27-2011, 08:52 PM
HomeGrown's Avatar
HomeGrown HomeGrown is offline
Vehicle: 2014 Ram 1500 "Black Express"
Rep:17
HomeGrown is on a distinguished road
I found a thread on another diesel forum a couple weeks ago when poking around before I got my truck. Looks real clean & simple, although PVC is not advisable to use in the engine compartment due to a toxic gas it gives off when heated. Plus, it also softens up when it gets hot. I think the black ABS pipe would be more appropriate if you were to build something like this. His design looks great, but material choice isn't the best (granted, there's not much choice in materials when sourcing materials from HD or Lowe's).
EDIT: I can't give the link here, it keeps changing the site domain name to ************* in the link. Do a Google search "Increase turbo whistle 80%" and you'll see the link on dieselbombers.
- Bill
2014 Black Express RCSB 4x4
Old 10-27-2011, 08:57 PM
snrusnak's Avatar
Rep:1388
I found THIS THREAD a couple weeks ago when poking around before I got my truck. Looks real clean & simple, although PVC is not advisable to use in the engine compartment due to a toxic gas it gives off when heated. Plus, it also softens up when it gets hot. I think the black ABS pipe would be more appropriate if you were to build something like this. His design looks great, but material choice isn't the best (granted, there's not much choice in materials when sourcing materials from HD or Lowe's).
PVC is alright to use for intake, people tend to over react a little with things like this. PVC is designed to handle temperatures well beyond 115 deg F degrees, which the intake is usually right around that temperature. CPVC for home water lines has to handle hot water from the water heater(120 deg F or higher), and regular pvc is much stronger. It takes A LOT of heat to distort pvc and emit gasses, trust me I've used a 1200 deg F heat gun to bend pvc and it took about 5 minutes of direct application before it started distorting.
Sean
Old 10-27-2011, 09:16 PM
HomeGrown's Avatar
Rep:17
When I did a custom turbo setup on my 2000 S-10, I used PVC, but it was on the pressure side of the turbo (temporary setup) and it got somewhat pliable on me, and I could smell it when I opened the hood. Plus, it was right in the middle of the engine compartment, not off to the side like it would be for an air intake application.
Anyway, this guy's setup looks like it would be pretty smooth-flowing.
- Bill
Old 10-27-2011, 09:52 PM
snrusnak's Avatar
Rep:1388
What grade pvc did you use? Doesn't really add up as underhood temps don't get any hotter than hot water temps do in a hot water heater. Boost isn't that much psi either compared to what pvc is rated for....odd. I wonder if you used the thin wall pvc stuff, I don't know what it's rated for, but I know schedule 40 will hold up, and I've used it before and it was fine for years.
Sean
Old 11-01-2011, 08:36 PM
HomeGrown's Avatar
Rep:17
I honestly don't remember what schedule it was, only that it was the common (probably 2") stuff from Home Depot. My somewhat "alarmist mentality" probably came from another alarmist.
But yeah, I hear you on the engine compartment temps... doesn't really seem as though it would have gotten hot enough to affect the PVC.
I may give this guy's intake design another look. It certainly would flow smoother than my gutted stock intake tube.
- Bill
Need help with cold air intake frozenfame Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 4 08-21-2011 12:18 AM
Cold air intake, program computer Darkknight3829 2010 Dodge Ram Forum 9 05-22-2011 03:49 PM
Mopar cold air intake issues... need help... js1977 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 6 05-19-2011 06:52 PM
Dirt road + Dust + Cold Air Intake tocou Dodge Ram 4x4 - Offroad Discussion 7 02-02-2011 03:49 PM
2009+ Hemi Ram MOPAR cold air intake chithead Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 9 02-01-2011 10:10 PM
