Old 09-06-2011, 10:15 PM
fsthawk fsthawk is offline
Vehicle: 2001 ram 2500
Color: Maroon
fsthawk is on a distinguished road
Question CB Power
Finally installing a CB in this truck. Where is the best place to grab power that is hot only with key on? Placement of CB will be in front of center jump seat. Want to place grounded fuse block under drivers seat and wire there. Have wires already there for what I assume was a disc changer that was removed. any Ideals?
Old 09-06-2011, 10:52 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Your cigarette lighter would do
Old 09-06-2011, 11:06 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
^^^ Agreed. Unless you have an aftermarket radio and want to tap into the remote output of it.
Old 09-07-2011, 08:59 PM
Color: Maroon
It's a CB. So where else can you get this power, I use the Cigarette lighter for other plugin items (IE. phone charger,DC/AC inverter) Don't want to overload the system.
Old 09-07-2011, 09:24 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Of the other items plugged in to the cig lighter....the only one that caught my eye was the DC/AC inverter. How many watts is it?
There are precious few circuits available without doing some serious wiring, so the cig lighter is about the best place to get switched power. If your inverter is 150W or less, then no problem, but if above that, and your actually drawing the bigger power, then it may be time for same fancy wiring.
brad
Interested in one of my mods?
Old 09-07-2011, 09:56 PM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
Its actually not a good practice to tap the cig lighter for power, even in the ham radio world.... Mainly cause the wire isn't the proper gauge for continuous use, hence why mobile radios come with a long red/black wire. Talking ham radios and 900mhz radios we use in EMS, we wire them to a master switch or directly to the battery...
Now if the wire is higher gauge at the cig lighter then radio wire, go for it (but be careful, consult your installation manual)
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 09-07-2011, 11:17 PM
Color: Mineral Gray
Rep:177
My uniden 510 xl in the truck just has a cigarette plug on it, some even come with them from the factory
I have a uniden 520xl(has a PA putput, not worth it in the truck is to loud) in my Taurus and I just have it into an accessory 20amp fuse, 2 years without any problems, I like it coming on and off with the key so my friends can't play with it and I had a tendency to leave it on.
You can look into a thing called add a fuse to do it the right way
Old 09-08-2011, 12:53 AM
Rep:2616
cb is directly wired from the battery
in line fuse
power controlled by CB switch
i am running major wattage
Old 09-08-2011, 12:56 AM
Rep:4072
That's exactly how I did mine in my Jeep ^^^^. Long as ya don't forget to turn it off when not in use, you'll be fine running it directly to the battery.
Old 09-08-2011, 12:06 PM
Drake371's Avatar
Rep:83
in line fuse
Thats the ideal way of doing it... especially when you start pushing watts
92 power ram no power to ignition please helplp justeric1agn Electrical 12 10-16-2014 05:43 PM
Problems with power mhillips Cummins Diesel Specific Topics 1 01-28-2011 12:47 AM
New guy from NY needs help with power door locks! awolb72 Newbie Checkin! 14 12-05-2010 05:07 PM
air ram power wire 4doordodge4life Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 10 04-26-2010 11:37 AM
Won't Start!!! Please Help racer965 Electrical 13 01-21-2010 05:10 PM
