Home Made Catch Can - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 09-07-2011, 04:02 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Both look very nice, so it's up to you. In my opinion though it's over $100 for a can... You may want to check out some others, they make them for go karts, usually plastic but some are pretty nice and usually much cheaper (like under $50). Just watch for the sizing/dimensions and inlet/outlet sizes.
I personally think that husky filter looks good(stickers removed) and it is very practical as far as having a drain and it unscrews as well. For $25 or so not bad....
Sean
Old 09-07-2011, 04:05 PM
moparornocar72's Avatar
Rep:630
I just realized on 3g's site that they have a scratch and dent sale on that big bully catch can. $90 shipped and all it is was a shipping accident that left them with some scratch or dent in them. Will someone take a pic of their catch overhead so i can see if you can even see the catch can very much
14.268 @ 95 MPH Full Trim
Old 09-07-2011, 04:12 PM
snrusnak's Avatar
Rep:1388
That's getting down to a more reasonable price...
Sean
Old 09-07-2011, 07:55 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
If you're ever around a home depot (maybe lowes too) check the campbell hausfeld water fuel seperators. You can do the whole mod for under 20 bucks if your interested.
Old 09-07-2011, 10:20 PM
Rep:630
I know they can handle the pressure, but I don't know about the heat, I have seen those things crack before and it not pretty when they do. I wouldnt want to think about what would happen if one of those burst while hot oil is in it. just my 2 cents. I will look around though before doing anything.
Old 09-08-2011, 08:23 AM
BadHazard's Avatar
BadHazard BadHazard is offline
Vehicle: 2006 QCSB, 1500
Color: Inferno Red
BadHazard is on a distinguished road
So the 2006's dont need one?
06 QCSB, 1500, Laramie, 4x4 50k. 18" Rockstars, K&N Drop in Filter, Muffler Delete, SuperChip
Old 09-08-2011, 08:31 AM
snrusnak's Avatar
Rep:1388
Well, none of them "need" it. It is just something extra some people like to add, it helps keep the inside of the intake a little bit cleaner, and helps for those that are racing/tuning to get a little more power and keep from detonating. Manufacturers make them the way they are for emissions reasons, but also to keep it from being another maintenance item. Most people who don't care about performance and such would be upset that they have to empty this can every so many miles, and would probably not do it....The factory's setup is good for the normal driver, but if you want to tune/race it would benefit you to add a catch can. Even if you don't use a catch can, you should change out your pcv valve every once in a while (every 50k miles or so). They are cheap and a properly operating one will help keep you from building up too much pressure inside the engine (this can hurt performance and also blow out seals causing oil leaks).
Sean
Old 09-08-2011, 08:38 AM
BadHazard's Avatar
Color: Inferno Red
Cool, well looks like this is on my to do list.
Old 09-08-2011, 11:02 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Its more an issue of "wanting" one not "needing" one.
The thing about catch cans are is you can mount them wherever. Get them away from your exhuast and your good to go. Spray paint the husky one (mask of a small viewing line before) and you have a custom color matched CC.
I still think that buying them is too much $$, no matter how pretty they are
2011 Big Horn 4x4 -SnowWhite-
Old 09-09-2011, 10:43 AM
RadioFlyer's Avatar
Rep:146
A catch can does not give you any more power. It helps prevent vented oil from your pcv valve from building up in your throttle body and cylinders. Your engine combustion chamber can only burn away so much oil and the excess builds up causing poor performance. A catch can will help your tunes last longer by trapping most of the oil. Just as a grease trap helps keep your sewer pipes in a resturaunt cleaner. And it does work and it does benifit performance by helping your tunes stay fresh and last longer but it does not give you any more HP. edit: A catch can is a wise investment for those who race their trucks. Those of you who think otherwise evidently do not have any experience with crankcase ventilation (nothing wrong with that, lol). And btw, glass water fuel seperators have been used since the ice age (lol) with no breaking problems caused from heat, lol!.
home made cai? mineault 2011 Dodge Ram Forum 2 08-07-2011 02:24 PM
This is the first stop I made after getting my new truck home Aqpokalipze Newbie Checkin! 8 08-04-2011 11:10 PM
Made it home from Iraq..... but not without Murphy's Laws MudFlap Off Topic Discussion 8 12-20-2010 02:02 AM
Home Made Catch Can Idea RootBeer Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 08-03-2010 12:29 AM
Home made CAI JR23 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 23 10-22-2009 10:12 AM
