Old 09-07-2011, 11:05 AM
dozier68's Avatar
dozier68 dozier68 is offline
Vehicle: 2010 Dodge Ram 4X4 Crew Cab
dozier68 is on a distinguished road
Question Headlight Aiming
This past weekend, I had to go to Lowe's to pick up some supplies for a fence that I am working on. After I got the truck loaded up with everything that I needed to get, it was squatting pretty good and we headed out back home after it had gotten dark. I noticed that once I got on the highway that I could see much better. The back of the truck was sitting down which made the headlights shine up in the air instead of directly on the ground in front of the truck. With the lights on high, they really seemed to stretch out and I could see stuff that I normally wouldn't have been able to see. This got me to thinking that maybe I can adjust the lights up a bit to help out the light situation ( I love the truck but have complained several times that the lights suck!) Does anybody know how to adjust the lights on a 2010 Ram?
Cherry Bomb Vortex with 5" tips, 20% tint up front, Truck Champ nerf bars, AVS Vent Visors
Old 09-07-2011, 11:46 AM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
There is an adjustment screw in the fender. Open the hood and look for a hole in the fender up top with an arrow pointing to it. Clockwise to raise and ccw to lower. Use a nut driver with 1/4" extension and 7mm socket.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 09-07-2011, 05:49 PM
RFarruggia's Avatar
RFarruggia RFarruggia is offline
Vehicle: 2010 dodge Ram 1500 ST
Color: Black Metallic
Rep:17
RFarruggia is on a distinguished road
just dont raise them too much because then when you have weight in the back they will be too high....learned that experience with atv+400lbs of hunting gear and food plus 4 guys in the cab. adjust them just a little higher and your golden
5.7HEMI 4x4 Leveling Kit 8K HIDs 20%Tint Front 5%Tint Rear Trailer Break Remote Start Tonneau Cover
Old 09-07-2011, 08:49 PM
FireWire's Avatar
FireWire FireWire is offline
Vehicle: 2011 Dodge Ram
Rep:12
FireWire is on a distinguished road
I complained to the dealer that the lights were aimed too low.
When I had it in for another issue when truck was new,they adjusted them up a bit. This was an improvement, but I have been thinking of pointing them up more.
I have had the truck loaded with my 600 pound bike and other stuff a few times, but only in daytime.I never really thought about them being aimed too high with a load on.
These are the worst headlights I have had on any of my last 6 vehicles. I think I will do something about them. ( lots of threads here on that subject )
Old 09-08-2011, 08:01 AM
dozier68's Avatar
At first I am planning on aiming them up just a little bit to try and find the point that I like the most. I don't usually do heavy hauling and very rarely at night so I don't think that will be much of an issue. This particular time that it was loaded so heavy that I had to take it easy over bumps because it was hitting the bump stops on the rear (well over a ton in the bed with three adults in the cab). Thanks for the tech infor cbrambo497. If I get a chance this weekend I will look into adjusting them and post the results here.
2000 Ram Headlight Issues jbaidas81 Electrical 4 10-09-2011 09:00 AM
Any PREVENTATIVE maintenance for the Clear Headlight Lenses? RammD Dodge Ram Detailing and General Maintenance Forum 7 03-29-2011 07:47 PM
Halo Projector Headlight Issue. Has anyone else had this? BigHornRam2006 Custom Dodge Ram Interior and Exterior Lighting 5 03-18-2011 01:35 PM
Headlight Removal?? Jbert84 2009 Dodge Ram Forum 21 05-31-2010 11:22 AM
Headlight command module 929nitro Electrical 9 04-06-2010 05:44 PM
