U0101, U0155 Codes and Instrument Cluster dead. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 09-07-2011, 02:31 PM
off2wildblue off2wildblue is offline
Vehicle: 2004 Dodge Ram 1500
off2wildblue is on a distinguished road
Default U0101, U0155 Codes and Instrument Cluster dead.
I have a crazy issue that has me freaking out. I have seen others with the same problem but few if any put the solution on line after it is fixed.
I have a 2004 Dodge Ram. The symptoms are:
1. All the dash gauges will read normal then all fail to zero and stay there.
2. No Bus in the odometer window.
3. All emergency warning lights illuminated.
4. Wipers don't work.
5. Codes U0101 and U0155 codes. U0101 Lost communication with TCM U0155 Lost communication with Instrument Cluster.
6. Won't let computer talk with the BCM or any of those modules.
7. Instrument Cluster test showed this on the odometer window:
My codes from the odometer are:
C Code
AA 00
AB 00
AC 00
AD 00
AE 00
00 00
Some say it is a BCM which my dealer says is not on this year truck so what is it called on the 2004? What has the communication with TCM and Inst. Cluster in common?
Any suggestions. Car will stall now and then but otherwise runs. Pic attached and was taken while idling.
I need help ASAP!
Thanks,
SAM
Old 09-07-2011, 06:25 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Seems like total computer failure to me as well. I just wouldnt know which one
All signs say BCM to me as well, but i dont know what types of computers your model has.
Heres a free bump for ya, but id start chasin down PCM(s) and trouble shooting
Good luck, electrical problems are a real situation
2011 Big Horn 4x4 -SnowWhite-
Old 09-07-2011, 08:42 PM
Would resetting the PCM help? I read the sequence of pulling the #23 fuse and doing the start sequence.
I also read that the PCM on the 3rd gen trucks have the BCM and another module built into it. Is this correct?
Thanks,
SAM
Old 09-07-2011, 10:31 PM
Resetting the PCM did not work. However, later it ended up being okay (it has done this before) so I assume it will come back. Would an Instrument cluster issue be intermittent like this?
SAM
instrument cluster problems prsch914 Electrical 19 08-10-2015 05:22 AM
2005 Dodge Ram Instrument cluster codes 2005CORAM Electrical 7 04-20-2010 06:12 PM
