Old 09-07-2011, 08:39 PM
Vinny's Avatar
Vinny Vinny is offline
Vehicle: 2011 Ram 1500
Rep:13
Vinny is on a distinguished road
Default 2011 Big Horn Needs Bigger Rubbers, but She Doesn't Want a Lift
I thought the title might grab some attention.
Before you ask - yes, I did the search. Didn't find anything conclusive, so I'm asking.
The question: I have a 2011 Big Horn. I'd like to swap out the existing tires and rims with an aftermarket set of rims equipped with Cooper Zeons, Nitto Terra Grapplers, or Toyo Open Countries.
I'd like to go a bit thicker on the tire (width, 285, 295?) with a taller profile (70?) but I'd prefer not to lift the truck up just yet. I'm guessing I'd need to stick with a 31-33" diameter.
What's the biggest I can go without rubbing the arms or wheel-well at full lock?
Thanks!
Current setup: Stock lift, stock 20" plastic chrome rims, 275/60/20 Wranglers.
Old 09-07-2011, 10:32 PM
Twisted10's Avatar
Twisted10 Twisted10 is offline
Vehicle: 2012 Dodge Ram QC 4wd
Color: Mineral Gray
Rep:25
Twisted10 is on a distinguished road
cooper zeon in 275 20's are around 33 or 34 inches tall depending on how much air u run.
if u want more height, u can go w/ 285/65/20 bfg's or nitto 295's. but u will have to put on a leveling kit. they are both 35" tires
i recommend if u stay w/ the stock tire size to go w/ the nitto's or the toyos. the coopers are not great tires, cheap, yes.. but they are noisey and suck in the snow
Old 09-08-2011, 12:05 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
I can personally vouch that the BFG AT KO's in 285/65r20's don't rub at all with a level kit. I think they're 34.7" tall and 11.5" wide and an awesome tire. I was looking at the Nitto's Trail Grapplers as well in 295/60R20 which are 34.5" tall and 12.1" wide but ended up going with the BFG's due to availability and I was a little concerned that the extra width of the Nitto's might cause issues with rubbing. I believe most of the issues people have with tire rub is due to the width of a tire usually and not the height. The Trail Grappler's also come in a 295/65R20 which are 35.5" tall and 12.1" wide but I think that would look better with a lift because it's getting pretty tall.
Old 09-08-2011, 02:44 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
275/60/20 is actually as close as you can get to 33" (32.99 to be exact). I have to say I haven't had my Cooper Zeons in snow yet but for everything else I absolutely love them.
I'm no expert but I think you are going to have a hard time fitting much of anything any bigger without leveling the front end. A lot of peeps go with 305/55 which is quite a bit wider but only about 0.20 inches taller than stock but even some of them have needed to level the front to keep them from rubbing.
I would suggest some Bilstein 5100 leveling shocks. Everyone seems to love them, you can still use them if you decide to do an actual suspension lift, and it would open up a whole new range of tire sizes....probably all the way up to a 35x12.50 (nearly 2" wider and a full 2" taller than stock).
Old 09-08-2011, 03:04 PM
Rep:367
Oh and BTW Ranye....great looking truck!!
Old 09-08-2011, 04:49 PM
Rayne's Avatar
Rep:73
Thanks bud, appreciate it!
Old 09-08-2011, 04:57 PM
What starquestbd22 said. Anything wider will rub. I am pretty sure you can't put a 285/75 on the truck...that's too tall at 35".
Old 09-08-2011, 08:24 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
I've been reading like a mad man on this very subject and 285's are the max on stock wheels and 305 if you go aftermarket with the proper offset.
2012 R/T 392
Old 09-09-2011, 04:35 PM
msoek's Avatar
msoek msoek is offline
Vehicle: Dodge Ram 1500 Sport
Rep:26
msoek is on a distinguished road
Nice Truck...
Did you only lifted the front ?
Old 09-09-2011, 10:26 PM
Vinny's Avatar
Rep:13
Thanks guys -ended up going with Cooper Zeon LTZ 275/60/20's and Konig LockNLoads. Stock size, yeah, but a better looking (and performing) tire. Twisted10 - I know you said they suck in the snow but the reviews have been positive so I'm going to give them a spin. Thanks all!
my new 2011 big horn shepyqx 2011 Dodge Ram Forum 10 06-28-2011 01:31 AM
My 2011 Big Horn 4x4 Silvereagle Dodge Ram Pictures - Photos 6 12-01-2010 12:18 AM
2011 Big Horn and Outdoorsman RootBeer 2011 Dodge Ram Forum 6 10-21-2010 12:45 AM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 12:28 PM
Suspension lift vs body lift usmcoorah Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 06-19-2009 01:13 AM
